Author Topic: 1967 CB450K0 Black Bomber Rebuild - By Royhall  (Read 241467 times)
Re: 1967 CB450K0 Black Bomber Rebuild - By Royhall
« Reply #375 on: March 04, 2024, 07:45:45 AM »
Hi Mo. Did you ever get the electronic ignition working? The hanging idle is often caused by worn out springs in the ignition advancer. Very common problem. Also check the clutch cable isn't fouling the throttle as it's close to it at the carb end. Did you fit the springs in the vacuum chamber?
« Reply #376 on: March 04, 2024, 06:45:24 PM »
Forgot to say, the kits I have ordered are made in Taiwan by a company called Daminedin and they have really good reviews. The dodgy items that people are struggling with are the Keyster kits. I also wonder if people are assuming that all 450 carbs are the same, there are at least 4 different versions of these carbs (not including the 500T version) and only a kit made specifically for that carb type will fit correctly. The ones I have ordered are specific for 14H and 14L only. I'm not surprised people are having problems with 450 carb kits. I have a chart somewhere detailing a lot of the changes, I will look for it tomorrow and post it here.
Sent from my Pixel 7 Pro using Tapatalk
Offline mo goldie
« Reply #377 on: March 04, 2024, 10:13:34 PM »
Hi Roy
yes the electronic ign is all on and working ok, the springs were all checked when I done the ign so they are ok and the clutch cable is not in the way...... the spring in the Vacuum chamber they was None in them so No I have Not got any of them Pity I would have put some in as I say if it came with them  :-[
the carb kits I got were from Wemoto and had the Needles with clips so set them at 3 up from bottom and the air screws were as I said set with a colortune and think they were out about 1 turn out in the end ...... wonder if Ashley had some kits would have got them :(
but the other thing is the charging as I don`t think it is as the battery after using the E/start a few times brings the Battery down...... Not sure how to check it as I don`t think by putting a meter across the battery tells me anything so don`t know how to check out the charging system ..again pity you Boy`s were Not anywhere near me for a look at if you know what I Mean.
« Last Edit: March 04, 2024, 10:17:54 PM by mo goldie »
Currant BIKES:
1980 Triumph Bonneville 750 T140/D Special Black & Gold
1962 BSA 650 Rocket Gold Star ( silver )
1977 Norton Commando 850 MK3  Interstate ( silver )
1977 Kawasaki KH400 Triple ( Green )
1999 Harley Davidson 1200S Sport (Diamand Ice silver )
1975 Honda Monkey st70 Dax ( Candy Sapphire Blue)
1967 Honda CB450 KO  ( Black Bomber )
1973 Yamaha Fs1-E ( Popsicle Purple )
1974 Honda CB750 K4 (Flake Sunrise Orange )
« Reply #379 on: March 05, 2024, 08:31:36 AM »
What are the significant differences Roy? Could it be that they are related to the K1 and 5-speed  engine components/characteristics? I would have thought that the needle and it's associated jets could be used on the later carbs and therefore closely match the original K0 engine characteristics. Problem is, I have a few K0 carbs (and 500T ones) but no later ones to compare the differences.
« Reply #380 on: March 05, 2024, 09:04:53 AM »
I am going to look into this later in more depth. I do know that the K0 carbs are quite different from the K1 mainly around the throttle spring area, plus a few of the K1 brassware items don't fit the K0. The carb body castings are also quite different. But for now, here's that table. You can see from this that the 14H and 14L are different to the rest.
« Last Edit: March 05, 2024, 09:06:53 AM by royhall »
Offline mo goldie
« Reply #381 on: March 06, 2024, 12:19:40 AM »
Hi Roy
Thanks for that but still can`t work out as the Bomber has Not got a Regulator I need to go more into how the wires come out of the stator and then go into the rectifier colour wise.......
the other thing you said about was the springs for the vacuum ...where can I get two them from as it might help with shutting of the slides faster and might help with the revs coming down quicker ?
I think that the wiring get beyond me as looked at the diagram and it more like the Birmingham road layout..... Not good with electrics :(
Currant BIKES:
« Reply #382 on: March 06, 2024, 08:09:33 AM »
Didnt think the 450 had a regulator, the rh swich brings more coils in when you turn lights on
« Reply #383 on: March 06, 2024, 08:39:50 AM »
Just read this post & the link to Roy's bike - very interesting & informative read.
« Reply #384 on: March 06, 2024, 09:19:16 AM »
Hi Roy
I thought I had sent you the colour matching of the old and new alternators Mo?
If not I will sort it out tonight for you. It's a fairly simple system really.
Sadly, I had quite a stock of the rare carbs piston return springs but they all went pretty quickly and I don't have any spares left. I even sold a set to Penelope Keith's husband !   :D So he must have a Bomber.  16186-283-305 was the part number if you can find them.
I was selling the whole upgrade kit at one  point but only have the odd part left now.
« Last Edit: March 06, 2024, 09:23:16 AM by AshimotoK0 »
Offline mo goldie
« Reply #385 on: March 06, 2024, 07:09:32 PM »
Hi Ash
I seemed to have lost where they went now... but if you can refresh me with it all would be great, as for the Carb kits that would have been good to have them, it was Roy who said about the springs as mine never had any in the carbs but I think they would help in keeping the slides down a bit faster to the bottom,
well My problem was the Needles Ash as in mine they were bent but when I got the new ones they came with the circlips on the Needles so just set them at 3 up.... as the ones in there were the same as you have in the picture which are fixed.
getting back to the charging I went and had a look at again today engine running battery went from 12.8 Volts engine off then 12.3 engine running put lights on and went down to 11.8 ....so I Know its Not Charging.... oh the Battery is as New and is an AGM .....
Oh I wonder if he has taken her on the back of the 450 :)
« Last Edit: March 06, 2024, 07:18:30 PM by mo goldie »
Currant BIKES:
« Reply #386 on: March 06, 2024, 09:53:55 PM »
Here is what I sent you before Mo.
Offline mo goldie
« Reply #387 on: March 06, 2024, 10:35:34 PM »
Are thanks Ash
all clear but I don`t have a red/white .........just white I think will have a look tomorrow  ;D
Pity about your carb kits ....... have you still got any of the needles without the circlips the ones in your picture ?
Mo
Currant BIKES:
« Reply #388 on: March 06, 2024, 10:51:22 PM »
Mo
May have needles and tubes .. can't promise though until I check.
Offline mo goldie
« Last Edit: March 07, 2024, 12:31:47 AM by mo goldie »
Currant BIKES:
