CB750
nogo
Topic: nogo (Read 11627 times)
Dave M
SOHC Expert
Re: nogo
Reply #15 on:
August 10, 2008, 06:02:34 PM »
If you look carefully on the outside they should be marked 5? if they're resistor caps. IIRC it's embossed into the plastic.
Dave
Melbourne.
Andy1976
SOHC Member
'76 Honda CB750F1
Re: nogo
Reply #16 on:
August 10, 2008, 07:24:40 PM »
Hi Dave, it looks like they are resistor caps.
Den, where do you get your ND X-24ES-U plugs from? I've been looking through DS catalogue but he does'nt have them listed, only NGK's. My local spares shop does'nt stock them either.
Andy
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
Re: nogo
Reply #17 on:
August 11, 2008, 09:34:22 AM »
Riding with old caps and missing rubber seals is asking for trouble. The first sign of rain and you will be spluttering to a halt.
Not expensive - get new ones!
Spitfire
Re: nogo
Reply #18 on:
August 11, 2008, 10:43:09 AM »
Hi Andy,
Had to do a web search for the plugs got them from this firm in the end
http://www.camskill.co.uk/
, Steve's right about the plug caps, cracked or missing rubbers means lots of fun in the wet, however I did buy 4 new ones from DSS, they are not cheap and within 400 miles one has failed already. So I dug out an old one which seems to work, maybe a good idea to shop around for them.
Den
Andy1976
SOHC Member
'76 Honda CB750F1
Re: nogo
Reply #19 on:
August 11, 2008, 05:42:31 PM »
Hi Steve, I've been in touch with DSS and sorted out some new caps. Replaced all four, just to make sure.
Den,thanks for the link, I'll order them plugs tomorrow.
Andy.
P.S. Steve, how did it go in France? Hope you enjoyed it.
CB750
nogo
