Author Topic: Breather routing  (Read 6553 times)
Offline sye
Breather routing
« on: February 27, 2019, 02:52:19 PM »
Hi, Can anyone tell me the routing for the 500 four engine breather pipe please and where it terminates?
Re: Breather routing
« Reply #1 on: February 27, 2019, 03:23:42 PM »
Over the plenium chamber. Then down along side the aircleaner case and the electrics area
Offline sye
« Reply #2 on: February 27, 2019, 03:35:36 PM »
Thanks John, so that's over the top of the carbs down the left hand side of the frame and then between the air cleaner case and electrics. Does it go down the forward gap between the air cleaner and electrics or down the back?
« Reply #3 on: February 27, 2019, 03:38:05 PM »
Forward.
Offline sye
« Reply #4 on: February 27, 2019, 03:38:40 PM »
Thanks muchly  :)
Offline sye
« Reply #5 on: February 27, 2019, 04:42:55 PM »
OK, I've tried routing the pipe and it's too big  :'( The OE part is unavailable, so I bought some 12mm ID x 16mm OD silicone hose and it's far too big. What size do you use? I suppose that 10mm ID x 12mm OD could be squeezed on but it starts to get expensive if I have to try loads to find the right one.
TIA
Offline sye
« Reply #6 on: March 02, 2019, 07:53:23 AM »
For anyone else that needs to know, the breather is 10mm ID and 14mm OD, which I know for sure is correct.
Can anyone tell me where the pipe terminates and how it's secured down the left hand side.
TIA
« Reply #7 on: March 02, 2019, 08:50:17 AM »
Just below swing arm level and it isnt
Offline sye
« Reply #8 on: March 02, 2019, 08:55:07 AM »
Thanks Bryan, I appreciate it.
Online deltarider
« Reply #9 on: March 02, 2019, 10:00:14 AM »
« Reply #10 on: March 03, 2019, 08:44:18 AM »
I remember those books Ken, usefull for holding down the cbx rocker cover while the evo stick set to hold tubber gasket in!
All the CD manuals i have are scanned from those when i was on good terms with local dealer.
« Reply #11 on: March 03, 2019, 10:39:42 AM »
Yup, think they were up to volume 12 when i was doing it!
Online deltarider
« Reply #12 on: March 03, 2019, 01:35:09 PM »
Is there a picture of the cover?
« Reply #13 on: March 03, 2019, 03:15:15 PM »
The "Blue" books were ring binders with many different bikes inside each one so the cover was plain.
« Reply #14 on: March 04, 2019, 09:38:04 AM »
Thats one of the sections that went inside the hardback folder.
