Author Topic: Build well under way  (Read 8825 times)
Offline sye
« on: March 09, 2019, 11:28:58 AM »
Things are moving on but I'm very busy with work, so don't have as much time as I would like to get on with it. Hey-ho, that's life.  ::)
Thanks to Mick for the switchgear, which I rewired and is now fitted to the bike. Graham is absolutely right about the headlight on/off switch positioning as I found out. Once the switch is located with the pin, it leaves a gap exactly the correct size for the switch as shown in the (blurry) picture. If it's still not correct in any way don't tell me as this is how it's going to be.  ;D
I have fitted an Electrex combined reg/rec and fitted a Scottoiler in the freed up space. I've also moved the electronic ignition to somewhere better than just shoved down the space between the mudguard and battery and thought I would share the locations with you. I think it looks very tidy and can't be seen once the side panels are on.
Still lots to do and I will post more pictures as i go.
« Last Edit: March 09, 2019, 11:31:19 AM by sye »
Online mickwinf
Re: Build well under way
« Reply #1 on: March 09, 2019, 02:41:35 PM »
looking good
« Reply #2 on: March 09, 2019, 02:51:31 PM »
Looking great Sye
« Reply #3 on: March 09, 2019, 03:10:14 PM »
Coming along great.
Offline sye
« Reply #4 on: March 12, 2019, 11:14:35 AM »
I managed to realign the aftermarket exhaust brackets yesterday and get the right side silencers lined up quite well. I've routed the throttle and clutch cables as per the great advice on here and replaced the coils and plug caps. Chain guard cleaned up quite well for a piece of scratched black plastic and Scottoiler install finalised.
Left side silencers today and then a quick check over of all bolts, rig a remote fuel supply and start it. Carb balance to follow, then the final bits and pieces before a test ride. Can't wait!  8)
« Reply #5 on: March 12, 2019, 11:19:30 AM »
We'll done Sye, its looking wonderful and I just love this moment, its always so exciting.
« Reply #6 on: March 12, 2019, 12:31:55 PM »
Comming on well Sye good luck with the start up always a milestone.
Online mickwinf
« Reply #7 on: March 12, 2019, 01:25:07 PM »
i agree with you oddjob, looks very awkward for the indicator switch.
« Reply #8 on: March 12, 2019, 01:52:44 PM »
Trig wires this switch in as a high / low switch and not as an on/ off switch. Most of these old Hondas, not all, have the hi /low on the switch gear that side, so he does it for continuity when riding so many different bike. We know where it is without thinking about it and that is a safety measure.
Offline sye
« Reply #9 on: March 12, 2019, 02:37:20 PM »
I'm still going to tell you, the switch is in the WRONG place. It meant to sit inboard of the main switch, on the small piece of bar which is still flat. If the gap is still left there between the grip and the switch I'd suggest you have the wrong grips, there is no gap there as standard, have you measured the grip and the amount of bar protruding when the switch is located? are they the same? although you say it's staying as it is consider this, the switch was introduced to stop the lights being accidentally switched off, as in the K0 switchgear, it's entirely possible you'll knock the switch going for the indicators etc and end up with no lights on a dark country road and I'll leave you to think on what may happen if that does occur. It's your bike but to me it looks horrible fitted there.
Oddjob, the bars are new ones for a 550, with the reinforced cable runs and switch locating holes. With the switch in the locating holes there is a gap on the left hand side that is exactly the same as the headlight on/off switch. The grips are not the hard as a hard thing ones but they are from DSS and the same size. The choices I had were to snap the locating pin and move the switch next to the grip, modify the switch and leave a portion of cable showing or to put the on/off switch in the gap. I chose to do the latter.
I still think that Graham is correct for a number of reasons. If you put it inboard then it has to be a long way in to clear the lever perch and just looks wrong. It looks correct where it is but I can see your thinking. It does block the indicator switch slightly but I don't think you could operate the switch by accident.
Moved on a bit this afternoon and got the left side exhausts fitted and lined up. It does seem that the key seems to be ensuring that the bracket dimensions are exactly correct. A couple of mm off and they just don't line up.
As an aside, I'm rather chuffed with the Scottoiler sprocket feed. It is secure, appears to work well and tucked right out of the way. Even better, I managed to retain the derailment plate so I'm well chuffed.
« Last Edit: March 12, 2019, 02:39:00 PM by sye »
Offline sye
« Reply #10 on: March 12, 2019, 02:53:52 PM »
I've just done a bit of a search in relation to where this switch goes and can find it in both places.  :-\
The first picture is poor but from a German road test in 1972. This shows it between the grip and the switch. The second is the cover of the K1 haynes manual, which shows it inboard.
The only way to know for sure would be from a European genuine Honda brochure or PDI manual from 1972. The only stuff I can find online is US stuff and they didn't have it fitted.
Offline flatfour
« Reply #11 on: March 12, 2019, 04:00:31 PM »
On my UK spec CB500 K1 (that I believe has the original handle bars and switch fitted) the headlight on/off switch is located inboard of the left side switch cluster. I also owned two new bikes of the same type in the 1970's and on both the switch was fitted as mine is now, inboard.
Offline sye
« Reply #12 on: March 12, 2019, 05:07:52 PM »
I wonder if you could do me a favour and measure the grip length if you get a chance please? Mine are 125mm or 5" approx.
« Reply #13 on: March 12, 2019, 05:35:14 PM »
As an aside but still relevant I feel, is the distance between the grip and the switch if positioned in board frim the main switch gear. This is my hand on the grip and the tip of my thumb only just reaches the indicator switch with my thumb at full stretch. For me to operate the head lamp on / off switch fitted in the inboard position, I would have to take my hand off the grip completely. Now, I know you only usually turn the head lamp on and off once at each ride but for me, personally, I don't think that's right. Yes, I know my hands are small but....just saying. [ Guests cannot view attachments ]
Offline flatfour
« Reply #14 on: March 13, 2019, 09:35:02 AM »
The grip length is 5 1/8" and the switch sits 3/4" inboard of the switch cluster. I have just taken (probably a poor) photograph of it that you are welcome to if you send me an e-mail address (I cannot manage to put photographs on the forum!) and may also have a better one from the past, I will look.
I've never thought anything of the headlamp on/off switch position, it all seems easy enough to operate for me and, as previously mentioned, both of my other bikes were the same.
