Dynamo Cover Removal
Topic: Dynamo Cover Removal (Read 3162 times)
Davelu88
April 06, 2019, 07:31:48 PM »
Hi All, i want to polish my Dynamo Cover & may be answering my own question but want some clarification , to remove do i just
remove the 4 outer screws & then the 3 inner screws around the coil and slide the coil out .
Thanks Dave
Re: Dynamo Cover Removal
April 06, 2019, 07:39:31 PM »
3 screws hold inner coil from outside and 3 hold outer coil from inside.
Davelu88
April 06, 2019, 07:52:17 PM »
Cheers Bryan, how do you get at the 3 outer that are behind the Honda name plate .
April 06, 2019, 09:32:49 PM »
You have to push the pins VERY carefully out of the clips, i believe there are small holes in the castings you can see inside the cover.
Big hint DO NOT kick or use the electric start with the generator cover off or you will shoot the oil gallery plug to somewhere you will not find it and get a large slippery patch on the floor!!!
Trigger
April 06, 2019, 10:54:38 PM »
Small holes in the rear and tap gently and evenly
Erny
CB750K7 CB550K1
April 07, 2019, 01:28:14 AM »
Dave
I was working on exactly the same topic :
http://www.sohc.co.uk/index.php/topic,18721.msg164085.html#msg164085
Get paint removed using paint removal (water based gel) and then cleaning and polishing using schotch brite
Trick is to push out 3 pins from inside. In my case it went very easy (once I was adviced what should I look for here on the forum
CB750K7 US model (1977)
CB550K1 US model (1975)
Davelu88
April 07, 2019, 10:01:17 AM »
Many thanks
