Feels a bit wobbly
Topic: Feels a bit wobbly (Read 6571 times)
Davelu88
Feels a bit wobbly
April 21, 2019, 03:11:52 PM »
Hi all my 550 feels a bit wobbly at front end especially at lower speeds . I'm not sure if the tyres have anything to do with it they are IRC , or could it be the forks , any input appreciated .
Johnwebley
Re: Feels a bit wobbly
April 21, 2019, 03:20:12 PM »
Check the steering head.to tight or loose can cause problems.
Check tyre pressure .28psi is perfect for mine.
What's IRC?
peterengland
SOHC Member
April 21, 2019, 03:39:10 PM »
Mine was wobbly at low speeds if I let go the grips then it was crazy wobbling! had a new front tyre and now perfect
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Davelu88
April 21, 2019, 03:56:05 PM »
IRC are the tyre make John !! . I'm thinking it's the tyres Peter , any recommendations on make .
April 21, 2019, 04:13:09 PM »
Metzeller mate
Davelu88
April 21, 2019, 04:30:06 PM »
Cheers Bryan , these are IRC which are USA make I think and are retro looking but they don't inspire much confidence on bends etc .
April 21, 2019, 04:39:54 PM »
ME 77 rear, perfect ME 11 front. Look same as original but stick better and if you shop carefully should not break the bank. Tubless is OK as long as you fit tubes!
Davelu88
April 21, 2019, 04:45:08 PM »
I better get shopping
April 21, 2019, 06:08:04 PM »
Do check the swingarm for play as well, it is surprising how much play at the back feels like its front end.
Davelu88
April 21, 2019, 06:59:11 PM »
Will do , like I say if you let go of the bars at 30 mph it wobbles like made but at 50 it's ok ( I'm not recommending doing that ) but the front just don't feel right .
Green1
Reply #10 on:
April 21, 2019, 08:30:11 PM »
My 750 came with IRC tyres they were OK not great but OK.
I finally got around to getting my 550 back on the road today after it ws running crap coming back from Crich last year.
Today out on the road it felt fat and slow to turn in at speed and woundered all over the road ( A kind of wobbly feeling)
I think mine is due to my rear shocks finaly giving up completely
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Davelu88
Reply #11 on:
April 21, 2019, 08:41:38 PM »
I might look at front forks again as they feel a bit soft and I think are bottoming out , would new springs take care of thatasive already put new fork oil in .
Green1
Reply #12 on:
April 21, 2019, 08:52:37 PM »
I put proggressive springs in the 750 and it felt much more planted after.But my origanal springs were way below the minimum required length. It could be worth checking wether yours are still within spec. If your bike is low mileage I should think there still OK
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
Davelu88
Reply #13 on:
April 21, 2019, 09:00:10 PM »
Bike only has 6K on it and im sure that is genuine, but i will check the spring specs. Also how do progressive springs work ?
Last Edit: April 21, 2019, 09:03:07 PM by Davelu88
Erny
CB750K7 CB550K1
Reply #14 on:
April 21, 2019, 09:40:03 PM »
Hi Dave
I just finished assembly of my 550K1.
My experience - wobbling at low speeds are caused by tire, its pressure (too low) and head bearing.
Forks - I did complete disassembly and cleaning, then assembly back and new fork oil Motul 10W, 160cc each leg.
I assume my fork is also 100% stock, springs lengths are 460mm. Despite I tried, I was unable to find service limit for my springs... Seems fork on CB550K and also later CB550F are different than my K1. Either I'm blinnd or just stupid, I did not find it in service manual, nor in Haynes book. I did not find exploded view of my fork in Service manual too (I have 2 small springs at bottom that are not shown in manual but are in spare parts catalogues on Partzilla, CMS....)
Wobbling/Tire - I would look at tire (do you have new one?), pressure? Maybe was standing deflating for years on one place and now tire has changed shape that is causing wobbling...
I have old( >20years) Kenda, it was wobbling too when I first tried bike when I received it.
BUT then I have replaced steering head bearing by tappered one and now, with old Kenda no wobbling at all, head bearing is a MUST change on these old bikes. Even new standard bearing will do the job...
I ordered new Avon Roadrider's AM26..
Note: On my CB750 K7 I have Battlax 45 and these are performing very good.
Last Edit: April 21, 2019, 09:44:01 PM by Erny
CB750K7 US model (1977)
CB550K1 US model (1975)
Feels a bit wobbly
