Author Topic: Is horn button also headlight flasher  (Read 3647 times)
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« on: June 09, 2019, 03:06:56 PM »
Hi all. Any thoughts welcome.
I had a vague recollection the pushing the horn button to the right is also a headlight flasher?
Many thanks. J
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Re: Is horn button also headlight flasher
« Reply #1 on: June 09, 2019, 03:10:00 PM »
If it's a UK 500/4 K1....the answer is yes.
Offline JezzaPeach
« Reply #2 on: June 09, 2019, 03:23:22 PM »
Many thanks. It’s EU/ Italian model K1 and has a sloping sided button that slides to the right, as well as pushing straight in for the horn.
I’m hoping it just needs a wire reconnecting in the headlight shell.
Do you think if it has the sloping button it should work? I’ve seen a pic of a version with a plain round button which I’m hoping would be the only type with no ‘flash’ function.
« Reply #3 on: June 09, 2019, 04:03:58 PM »
Your switch is the same style as the UK model then, so im assuming yours has the same functions but, I personally don't know if both should be wired in on your spec....being an EU/ Italian they may have had different lighting compliance regs but just used the same style switch as UK 🤔🤔🤔
Offline JezzaPeach
« Reply #4 on: June 09, 2019, 04:20:02 PM »
Many thanks again. Guess it would be logical if it was meant to function. I expect the Italians would have wanted it to! Currently the wiring is external on non original bars so I could run a cable easily.
Regards J
« Reply #5 on: June 09, 2019, 04:24:21 PM »
If it is supposed to work it is not an external wire but wired inside the switch
Offline JezzaPeach
« Reply #6 on: June 09, 2019, 04:34:50 PM »
Yes. Unfortunately on mine the original bars were replaced with ones without wiring holes and the switches have been modified with holes and the wires are taped together and go externally to the headlight. Not pretty! One day I’ll replace with bars with the right wiring holes. I’ve not seen 500/4 ones but there are some 400/4 ones that look possible.
Offline JezzaPeach
« Reply #7 on: June 09, 2019, 07:07:53 PM »
Found the dark blue wire was plugged into the wrong connector. Flasher now working!
  ;D
Many thanks.
Offline Green1
« Reply #8 on: June 09, 2019, 08:26:49 PM »
Easily done and easily fixed there's a bit of a nest in there.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
