Author Topic: CB750F1 Wiring  (Read 1823 times)
Online martin_uk
CB750F1 Wiring
« on: June 15, 2019, 10:48:42 AM »
Finishing my final F1 project and trying to sort out wiring.
I bought a repro wiring loom from DSS, but having trouble finding the correct wiring diagram.
Its a UK bike reg in Feb 78, but suspect earlier manufacture, as I heard sales dropped off, delaying registrations.
It has a frame number CB750F-10406xx (x to hide)
The wiring diagrams I have all show the horn switch providing an earth to horns with a switched live feed to them .
My switch supplies a live feed to horns which have a permanent earth.
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline mickwinf
Re: CB750F1 Wiring
« Reply #1 on: June 15, 2019, 11:38:21 AM »
if its similar to the 500/550 set up it depends which type of switch you have which does vary from US to UK spec. do you have a combined flasher/ horn button or horn only? if its horn only the power goes via a black wire under tank to one terminal of horn, then from other terminal via a light green wire to horn switch then to earth through handlebars when you press horn switch. With the flasher arrangement type you get a live feed to the switch, then when you press the horn button it connects to the light green wire to the horn terminal, then goes to earth via a short lead from the other horn terminal to the mounting bolt on the horn mounting bracket. Hope that makes sense and it is similar on the 750.
Re: CB750F1 Wiring
« Reply #2 on: June 15, 2019, 06:13:38 PM »
Also at about the same time the starter button changed due to the Yanks having permanently on lights, early ones earth to bars later ones send power to solenoid.
