Author Topic: Play in caliper  (Read 2803 times)
Offline Athame57
Play in caliper
« on: June 16, 2019, 12:50:44 PM »
I have about a millimetre of play when I put the brake pad back into the fixed caliper on my CB400F2, is that ok? I'm still forever having trouble with a squeak to make the public wince.
I brake for animals!
1978 CB400F2 named Elen.
Re: Play in caliper
« Reply #1 on: June 16, 2019, 01:26:39 PM »
The clearance between fixed pad and disc should only be 0.15mm. A squeaky front brake is very common on the CB400/4. I tried everything to no avail but had the disc skimmed and that has sorted it for 95% of the time.
« Last Edit: June 16, 2019, 01:29:34 PM by Nurse Julie »
Offline mike the bike
Re: Play in caliper
« Reply #2 on: June 16, 2019, 04:20:32 PM »
I cleaned up the pads and the insides of the caliper surfaces, applied red rubber grease and the squeal was completely  eradicated.
For a few days, it's back to normal.   I'm thinking about a shim of rubber on the back of the pad.  I'll report back when I've done it.
Just go back from a 120 mile round trip.
Re: Play in caliper
« Reply #3 on: June 16, 2019, 04:29:14 PM »
Mine only squeaks now when braking at very, very low speed. It used to be all the time and was an absolute nuisance.........and embarrassing.
Offline Athame57
Re: Play in caliper
« Reply #4 on: June 16, 2019, 04:42:04 PM »
I'll measure it properly and see. I've greased everything I dare to grease and the squeaking has stopped....touch wood!
Offline Athame57
Re: Play in caliper
« Reply #5 on: June 18, 2019, 02:33:09 PM »
Hi Julie
That is how I've set it up, I see I've been misunderstood though, what I mean is the sides of the brake pad and the play between that and the walls of the recess it sits in, I seem to have about a millimeter of play there....
