Author Topic: CB500K0 piston rings  (Read 4301 times)
Offline Raymond_Y
« on: June 18, 2019, 04:40:30 PM »
Has anyone used Cruzinimage_uk piston rings?  When I came to refit my pistons yesterday, I found one ring broken.  Many expletives were voiced as the were all fine and within spec when I had removed and refitted them to clean the pistons.
Raymond
Raymond
1971 CB500K0 (being rebuilt)
1977 CB550K3 (bases for future 650 cafe racer)
Q plate CB550 in bits
Re: CB500K0 piston rings
« Reply #1 on: June 18, 2019, 06:13:48 PM »
What size and which rimg i MIGHT have a few odd ones
« Reply #2 on: June 18, 2019, 06:29:33 PM »
Cruzinimage piston rings are great, use them very regularly with no problems whatsoever.
« Reply #3 on: June 18, 2019, 06:48:24 PM »
Should also have mentioned if you are unaware, Cruzinimage UK are in Japan. So you need to add about 34% on top of the price of the rings to take into account post, duties and Parcelforce kidnap fees.
Offline Raymond_Y
« Reply #4 on: June 18, 2019, 07:01:34 PM »
Bryan, it is a bottom compression ring (i.e. the middle ring) that is broken.  The rings are standard.
Thanks Bryan
Julie, will duties and kidnap fees apply if the cost is only £36 + £9 p&p.
Raymond
Raymond
« Reply #5 on: June 18, 2019, 07:50:33 PM »
Thanks Bryan
Raymond
Yes, the limit is £15.
« Reply #6 on: June 18, 2019, 09:55:03 PM »
 Found a Honda  NOS set in my parts bin, if your interested £10 plus post.
Offline Raymond_Y
« Reply #7 on: June 19, 2019, 08:46:09 AM »
Trigger, PM sent.
Many thanks
Raymond
Raymond
