Author Topic: Intro  (Read 4679 times)
Offline Trygve
Intro
« on: December 02, 2008, 03:48:08 AM »
My name is Trygve Klem, and I live outside Lismore, NSW, Australia. I have recently bought a CB 750 SS 1978 model. Which I have started to sort out the various areas needing some attention. When I opened the dynamo cover where the stator is, some oil leaked out. Is there supposed to be oil in there. (as you can guess, it's a long time since I have owned a motorbike.
Re: Intro
« Reply #1 on: December 02, 2008, 07:10:58 AM »
Hello from all in the UK.
I don't think that a little bit of oil under the alternator cover is bad or uncommon.
You will probably meet more Aussies on or sister (global) site: www.sohc4.net - if you haven't found it already, it looks the same as this (uses the same software). Use the same username so that we all recognise you!
Offline Trygve
Re: Intro
« Reply #2 on: December 05, 2008, 12:47:04 AM »
Thanks for the info. I have had the stator checked and it needs rewiring
Re: Intro
« Reply #3 on: December 19, 2008, 09:55:56 AM »
Thats very unusual as they are extremely robust and normaly only get damaged by accidents
