SOHC.co.uk Forums > CB750
Gear Box Outer Cover
<< < (2/2)
bucksfizz:
New oil pressure switch arrived today, fitted it, and... oil light now comes on - hurrah.
Now let's hope it goes out again when I fire her up.
I'll add some more oil to the tank at the same time, Julie - not too bad running low oil on a dry-sumper, though.
Nurse Julie:
--- Quote from: bucksfizz on July 06, 2019, 04:13:32 PM ---New oil pressure switch arrived today, fitted it, and... oil light now comes on - hurrah.
--- End quote ---
I don't like anything running low on oil, wet sump or dry sump.....its unnatural 😁😁😁
Trigger:
When you tighten up the mission cover, make sure that you have not trapped any wire that run in the channel at the back of that cover.
Strange to see a early head on a K3  ;) ;)
bucksfizz:
--- Quote from: Trigger on July 06, 2019, 09:21:17 PM ---When you tighten up the mission cover, make sure that you have not trapped any wire that run in the channel at the back of that cover.
--- End quote ---
What's a "mission cover"? (My ignorance of these machines is shining through.)
How can you tell it's an early head?
If it is an early head, it's probably not too surprising, given the bike's 46 year age.
Trigger:
Mission cover ( transmission / gear box cover)
Early head ( 1969 to 1972 )  ;)
I can tell its a early K0 to K2 by the fins.
Navigation
[0] Message Index
[*] Previous page
Go to full version
