Author Topic: Hydraulic Clutch  (Read 7814 times)
Offline JonnyB
  • Repeat: It's only a Hobby, It's only a Hobby....
    • BatchScan
Hydraulic Clutch
« on: January 23, 2009, 12:36:39 PM »
Anyone had experience bleeding a Hydraulic clutch? I've got a CB650 and the clutch is only active in the first half inch of pull on the lever.
It has new plates and I've attempted to bleed it several times
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
Basket Case -  K100/1200 hybrid
John
https://batchscan.co.uk/
Re: Hydraulic Clutch
« Reply #1 on: January 23, 2009, 08:29:15 PM »
Do you mean you go from slip to full lock up in the first 1/2 inch, cos if so i think that would be right
Offline JonnyB
    • BatchScan
« Reply #2 on: January 24, 2009, 08:13:58 AM »
Yes, but it seems I have little control, it still seem on or off, there is slip but no degreesof slip, if that makes sense
John
« Reply #3 on: January 24, 2009, 09:37:34 AM »
Yup, that makes sense, hydraulic clutches were only just starting when i quit spannereing so i cant be definitive but what you describe sounds more like parts incompatibility rather than a bleeding problem.
? are all the parts original off the same model
Offline JonnyB
    • BatchScan
« Reply #4 on: January 24, 2009, 09:44:36 AM »
It's the US import model, and my local bike shop (DJ Bike Spares in Lincoln - Good guys) had a right time getting them, but in all dimensions they seem to be identical to the ones that were in  it. They are Pattern parts!!
John
« Reply #5 on: January 24, 2009, 09:56:56 AM »
John, if the hydraulics are working correctly, it's the same as having a cable.
Are you sure the clutch is OK/adjusted ??
Offline JonnyB
    • BatchScan
« Reply #6 on: January 24, 2009, 10:17:19 AM »
Looks like I'll have to have another go at bleeding, I'll keep you posted
John
« Reply #7 on: January 24, 2009, 02:15:28 PM »
If its working I really dont think its an air problem as that would just make it spongy and not work till the last bit by the bars---not in the first 1/2 inch.
Steve could be right in is there any mechanical adjustment at the clutch end?
I Have the Honda blue book manuals for the CB650 and the CB650SC addendum but not the later one sorry
Offline Yoshi823
  • Biker to the bone...
« Reply #8 on: November 21, 2009, 09:05:45 PM »
Of all hydraulic clutches that I have come across there is a pushrod.Few bikes have a decent oil supply to them,so I usually remove the rod,clean it with some emery cloth,check for straightness on a piece of glass and lubricate with some fresh oil before replacing.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
