CB350/400
Clock refurb
Topic: Clock refurb (Read 10937 times)
10tenmen
SOHC Associate
A good old un.
Clock refurb
September 04, 2019, 02:40:10 PM »
Just started on the refurbishment of my 400f clocks largely due to fading of the dial fascia, the actual glass was filthy but has cleaned up really well. I also had a horrible bent trip meter shaft that has been successfully straightened.
I have ordered the new dials from CB750 faces along with the rubber grommet for the trip.
I managed to warm up the twist bit for the trip and pry it off saving me unscrewing the trip shaft.
Anyone any ideas for what paint to use for the needle ends which is a red colour originally, also what colour is the black on the surround gloss or matt, I’m going to wet and dry them before painting.
Thanks Gary
Last Edit: September 04, 2019, 02:41:56 PM by 10tenmen
taysidedragon
Re: Clock refurb
September 05, 2019, 12:07:00 AM »
I used bright red Humbrol model paint on my needle. That was the easiest part of the job.
The outer case is satin black.
kent400
SOHC Expert
Re: Clock refurb
September 05, 2019, 08:04:04 AM »
Revell SM332 same colour available in Humbrol but not sure of their reference number. Available from most model shops in very small tins
10tenmen
SOHC Associate
A good old un.
Re: Clock refurb
September 05, 2019, 08:18:34 AM »
Thanks for the replies both very helpful Peter I have a model shop nearby I will go there thanks.
10tenmen
SOHC Associate
A good old un.
Re: Clock refurb
September 08, 2019, 05:31:44 PM »
Got the paint to touch up the needles and the 70mph mark On the new fascia just waiting for the paint for the cups which I have prepped with wet and dry.
Before and after pics.
10tenmen
SOHC Associate
A good old un.
Re: Clock refurb
September 10, 2019, 08:00:50 PM »
All done with the clocks turned out ok not too sure about the led bulbs may try some less bright.
Windycorner
Newbie
Re: Clock refurb
September 11, 2019, 10:34:38 AM »
Superb job, that's spurred me to finish mine, I have also been using LED's and they are bright, I have tried several types but not found the perfect one yet, if you find any would you let us know.
Neil
Neil
CB750FA
CB400F2
K2-K6
Re: Clock refurb
September 11, 2019, 11:25:06 AM »
Nice work, good outcome.
If you want to tone down led individually, you can use nail varnish directly on the surface to add neutral density with grey, or maybe green to bring closer to face colour.
Edit;- thinking it further, conventional bulbs are much more yellow than white led, pale yellow should head them back towards original but careful selection could give halfway house.
Or, sanding the surface, if they are clear led lens, would increase the diffusion and hence softness of the light source to mitigate some of the localised brightness.
Last Edit: September 11, 2019, 11:33:47 AM by K2-K6
10tenmen
SOHC Associate
A good old un.
Re: Clock refurb
September 11, 2019, 01:11:00 PM »
Brilliant suggestions thanks everyone
TrickyMicky
Re: Clock refurb
September 20, 2019, 08:09:28 PM »
Re. LED bulbs, if you trawl through Fleabay there is someone who sells coloured instrument LED's including green which could possibly be a suitable solution. Likewise if you want LED's in your rear light, make sure you use RED bulbs only, the light particles from a LED mean that if you use white bulbs in a red lens the result will be a pink light.
Riceman
Newbie
Re: Clock refurb
Reply #10 on:
October 21, 2019, 03:15:44 PM »
Any more feedback/update on this topic as I am looking to buy some LEDs for my clocks?
10tenmen
SOHC Associate
A good old un.
Re: Clock refurb
Reply #11 on:
October 21, 2019, 03:42:33 PM »
I bought a couple of sets of these and used a light yellow nail varnish to diffuse then worked a treat.
https://www.ebay.co.uk/itm/NEW-2-X-WHITE-LED-BULBS-12-VOLT-BULBS-233-T4W-BA9S-SIDE-LIGHT-INTERIOR-233LED/381965379193?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Riceman
Newbie
Re: Clock refurb
Reply #12 on:
October 22, 2019, 05:40:49 PM »
Thanks, I will give those a try.
CB350/400
Clock refurb
