Author Topic: new side panel painted  (Read 7096 times)
Offline ace cafe racer
« on: September 27, 2019, 06:15:49 PM »
finally got to the end of painting the new side panel, just a bit of compounding to do. finally got the new V5c now registered as Historic vehicle. Cant decide whether the number plate I made looks OK or not, it is to spec.
1977 Honda CB750 F1
2000 500 Royal Enfield Bullet
Re: new side panel painted
« Reply #1 on: September 27, 2019, 06:25:24 PM »
The plate and the side panel look great Mick 👍👍👍
« Reply #2 on: September 27, 2019, 06:42:49 PM »
They both look great, nice job
Online mickwinf
« Reply #3 on: September 28, 2019, 04:07:39 PM »
very nice but is a black plate legal, thought after 73 should be yellow
« Reply #4 on: September 28, 2019, 04:14:29 PM »
As long as its registered as Historic Mick, it can have black / white. It also rolls over yearly along with the Historic entitlement. So now, my 78 reg bike can have black / white as registered as historic...but i haven't bothered, I'm still wearing yellow, I think a T reg bike with black / white plates just looks stooopid.
« Last Edit: September 28, 2019, 04:19:12 PM by Nurse Julie »
Online SteveD CB500K0
« Reply #5 on: September 28, 2019, 04:16:15 PM »
Per Julie, I understand it’s now a rolling date.
Also, nobody seems to give a monkeys nowadays anyway…
« Reply #6 on: September 28, 2019, 04:17:35 PM »
Agree Steve. I see plenty of brand new bikes with black / white plates fitted.
Offline Phil Ward (RIP)
« Reply #7 on: September 29, 2019, 09:35:20 AM »
Did I read on a previous post that after a certain date, the plate numbers had to be in a set format/plate size over 2 lines - sure it was on a DVLA link someone posted - I'd prefer to be wrong on this as the plate format over 3 lines on this post would suit my CR and the K6 cafe racer in on with now
Sent from my Moto G (5) using Tapatalk
« Reply #8 on: September 29, 2019, 09:44:52 AM »
You can have 3 lines Phil
« Reply #9 on: September 29, 2019, 10:11:48 AM »
And the font to use is called Charles Wright if making your own
1977 Honda CB750 F1
« Reply #10 on: September 29, 2019, 11:53:37 AM »
Does the last line on the guidance not mean you can't have 3 lines after 1st January 1973 - 'must be set on two lines'?
(Attachment Link)
« Reply #11 on: September 29, 2019, 12:09:12 PM »
Not sure I posted correctly last post so
- Does the last line on the guidance not mean you can't have 3 lines after 1st January 1973 - 'must be set on two lines'?
« Reply #12 on: September 29, 2019, 12:10:54 PM »
Just re-read first part - so get it now - senior moment!
So is there a kit to make the 3 line plate?
« Reply #13 on: September 29, 2019, 12:18:32 PM »
It's typical DVLA confusion Phil. It says 'Vehicles' in the first part of that page and then down the bottom says motorcycles and tricycles 🤔🤔🤔 I'm going by the first bit which relates to the 73/78 bit, implying that as ling as its registered Historic, its OK. The last bit about bikes etc, is not saying the same as what's at the top of the paragraph. Once again though, I see new bikes with black and white, on 3 lines.
« Reply #14 on: September 29, 2019, 12:25:41 PM »
I just got some suitable metal painted it black cut the numbers in white vinyl on my vinyl plotter, stuck them on and clear varnished over. I would gladly cut the nos for you if you wish.in return for all the help given on this forum.
« Last Edit: September 29, 2019, 12:31:00 PM by ace cafe racer »
1977 Honda CB750 F1
