Author Topic: Stopping hoses “welding” to petcocks  (Read 6555 times)
Offline paulbaker1954
« on: October 09, 2019, 07:35:07 AM »
Rejuvenating and old post maybe but anyone any tips for stopping the carb hoses from seemingly welding themselves to the petcock petcock outlet tubes. Seems they will slide on easily and the be an absolute bastard to get off a few weeks later.
I think I tried Vaseline but that wasn’t much help once.
I guess I need some lubricant that does not get eaten away by petrol
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline Brian.
Re: Stopping hoses “welding” to petcocks
« Reply #1 on: October 09, 2019, 07:56:50 AM »
I use a trace of silicone grease, perhaps you could also use brake grease?  Neither attack rubber.
« Reply #2 on: October 09, 2019, 07:58:27 AM »
Been trying for 40 yrs and not found anything that works
« Reply #3 on: October 09, 2019, 08:13:46 AM »
Petcock ? Its a fuel tap and they should stick to the outlets, that how they don't leak. To easy get the pipes off, there is a little tool that you clamp to the pipe and turn   ;)
Offline deltarider
« Reply #4 on: October 09, 2019, 08:14:15 AM »
Never had that problem. I should add I've abandoned those little clamps since decades.
Offline Erny
  • CB750K7 CB550K1
« Reply #5 on: October 09, 2019, 08:16:17 AM »
Guys, I fully understand your feelings... Looks I'm not the only one having this issue - I had to change leaking pectock on my CB550K1 back in April, from dual outlet to single outlet so I had to manage hoses split into 2, used T splitter and piece of U shaped copper tube for 1 line, it went on it easily, I was even afraid it will leak - after 4 months of use I spent 30mins using tiny screwdrivers and WD40 to remove hose from this copper tube  >:(, I almost cut hose being so frustrated, but it would mean to install new one that would be even more difficult...
Now have dual outlet replica petcock from 4into1, but seems it is leaking too... :(
CB750K7 US model (1977)
CB550K1 US model (1975)
Offline Erny
  • CB750K7 CB550K1
« Reply #6 on: October 09, 2019, 08:17:20 AM »
Intersting - would you mind to share some info about that tool?
« Reply #7 on: October 09, 2019, 09:34:10 AM »
As Trigger's post,  if you twist them it releases the bond before moving them downward.
But if you want something to try,  consider sudocream as it'll leave zinc oxide there to stop the rubber bonding.
« Reply #8 on: October 09, 2019, 09:49:24 AM »
Where can i find said little tool
Offline Moorey
« Reply #9 on: October 09, 2019, 09:59:53 AM »
Do not push them all the way on leave a little room at the end so you can get some narrow nose pliers across the end and use them to push the pipe off as against pulling on the pipe. If you just try to pull the pipe it just ends up working like one of those Chinese finger cuffs you had as a kid. Like Trigger said  twist the pipe first.
Offline Erny
  • CB750K7 CB550K1
« Reply #10 on: October 09, 2019, 11:30:23 AM »
Didn't work in my case. Hose was nearly 1 inch on copper tube no movement at all, was like welded
Online Spitfire
« Reply #11 on: October 09, 2019, 11:30:42 AM »
If mine sticks I just insert a screwdriver and twist, when I put it back on I lubricate it with a little fuel.
« Reply #12 on: October 09, 2019, 05:58:14 PM »
Ordered one of these - see how it works out
« Last Edit: October 10, 2019, 07:29:21 AM by paulbaker1954 »
Online JamesH
« Reply #13 on: October 09, 2019, 06:53:17 PM »
I use one of these..
Offline Athame57
« Reply #14 on: October 10, 2019, 11:33:52 PM »
I really think the only lubricant you'll find reliable for this is....Elbow Grease!  ;D
I brake for animals!
1978 CB400F2 named Elen.
