Author Topic: Cold starting procedure?  (Read 1744 times)
Offline paulbaker1954
« on: November 04, 2019, 07:48:29 AM »
I always seem to have trouble starting my bike from cold.
I  tend to put choke fully on and wind throttle open, fires easily but the seems to kind of flood out and die.
I have tried various combinations of choke and throttle position but just can’t seem to get right technique
Bike runs perfect when warm by the way
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline Erny
  • CB750K7 CB550K1
Re: Cold starting procedure?
« Reply #1 on: November 04, 2019, 08:02:14 AM »
Paul, my way:
- full choke by left hand
- open trottle by right, keep it open
- start (it fires immidiately)
- right after it fires, choke off fully or partially, while still keeping trottle open, keeping full choke makes mix too rich im my case and engine tends to die
- keep trottle open till engine is not warm enough to keep idle or use idle knob and screw it in to increase idle rpms.
CB750K7 US model (1977)
CB550K1 US model (1975)
« Reply #2 on: November 04, 2019, 11:36:25 AM »
Use full choke. About quarter throttle. When it starts. Open choke slightly. Warm engine at 2k rpm.
Should accept fully open choke quite quickly.
I tend to start it on main stand.put in gear to warm gearbox as well.
If you blip the throttle with clutch pulled in.it will separate the plates nicely.
Ready to ride off
