Author Topic: Gerben question  (Read 6014 times)
Offline paulbaker1954
Gerben question
« on: December 16, 2019, 05:03:51 PM »
Hi folks
I am still having running issues and sure it’s a carb issue.
 Bike starts fine and idles  smoothly but then feels like fuel starvation on the road.
Seems to run ok with full choke on but than as soon as I come to a stop she stops, I think due to too much choke.
Close choke restart one off ok again but then feels like it’s fuel starved and has no power.
I have adjusted the idle screws but makes no real difference and float levels are ok.
On reflection these carbs have never been right and I am seriously thinking of sending them to Gerben for a full overhaul or trade in for one of his refurbished sets.
That said it’s a big expenditure and just wondered
a) are his carbs usually spot on
b) am I wasting my money
c) Any bright other ideas
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline Menno
  • www.tanklackieren.de
Re: Gerben question
« Reply #1 on: December 16, 2019, 07:39:26 PM »
A refurbished set of cabs still need to be adjusted.
I bought a vacuumgauge set on ebay for small money and did it myself.
Took me whole afternoon but the bike runs great.
Even without the original filter (I bought a design breadbox).
Come to think of it...
Couple of things to think about:
- is your airfilter new or 40 years old?
- I have noticed that the original clamps to secure the intake rubbers on the manifolds might not tighten enough after 40 years.
These clamps have a maximum of how tight you can tighten them. I replaced them for nice looking rostfree clamps which don't have a maximum. You can tighten them more than the original ones so any false air (?) can be prevented.
How big are your main jets?
Re: Gerben question
« Reply #2 on: December 16, 2019, 08:27:14 PM »
Have you considered something like this http://www.sohc.co.uk/index.php/topic,18831.0.html to at least get a quantified look at what it's burning,  or not.
Re: Gerben question
« Reply #3 on: December 16, 2019, 08:42:59 PM »
I just received some 350/4 carbs I bought from Roy that Gerben had restored and they look generally spot on,  for my 400/4. They don't have KeiHin jets in them though (not sure on needles) so I am going to swap for original KeiHins, as I need to jet up anyway from 350cc to 408cc. I know he doesn't fit or recommend Cruzinimage parts .... so that's a big bonus IMHO.  ;)
If I am being picky he spray paints the carb plate by the looks of it when this item was bare alloy originally (not sure on his reasoning for doing this). I am also going to swap some of the screws for original style  JIS ones .... but I am a picky s*d.
Offline deltarider
Re: Gerben question
« Reply #4 on: December 16, 2019, 09:56:53 PM »
How did you find that out?
Quote
I replaced them for nice looking rostfree clamps ...
Where did you find those?
Offline Menno
Re: Gerben question
« Reply #5 on: December 16, 2019, 10:58:14 PM »
I noticed that (after I've bought several used sets on ebay) those rubbers between the carb and head were a bit loose.
Every one of them. I didn't pay attention to it first but after putting on the original clamps I noticed that when I would tighten them till maximum (those 2 stops hit each other) there was still play.
Naturally after putting the rubbers on and pulling them off again in the last 40 years they were not as tight as they should be.
So I have bought these:
https://www.ebay.de/itm/Schlauchschellen-Edelstahl-V2A-mit-Schneckengewinde-DIN-3017-W2-von-8mm-180mm/253264148517?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
quite cheap I think 8,90 and free shipment in Germany for 10 - and they look good too.
With those clamps I could get te rubbers on much tighter. Or actually as tight as they needed to be.
Since then I am advising everyone to get rid of those original ones.
Of course they are not original. That might be a nono for many. But the bike preforms really well with those.
I am going tho replace them on my 750 as well..
Offline deltarider
Re: Gerben question
« Reply #6 on: December 17, 2019, 08:21:36 AM »
Thanks Menno. They look good. I had planned to 'line' the originals with a thin layer of rubber, but I might go for these. I mean who could resist Edelstahl? ;) Which 'Spannbereich' did you order?
« Last Edit: December 17, 2019, 08:26:31 AM by deltarider »
Offline Erny
  • CB750K7 CB550K1
Re: Gerben question
« Reply #7 on: December 17, 2019, 10:16:19 AM »
Hi folks
Paul,
I assume bike was working fine before. Are you sure that fuel is flowing into carbs w/o any blocking? Don't you use fuel filter? If so, try to remove it.
If fuel flows OK and float levels are OK - then it looks to me you have some air leak (too lean mix on idle). Are you really sure your float levels are OK? Did you make clear tube test?
before sending carbs to Gerben, I would check if fuel flows through petcock (sometimes vent in tank cap can be clogged), check airleak and eventually check/clean jets.
« Last Edit: December 17, 2019, 10:51:51 AM by Erny »
CB750K7 US model (1977)
CB550K1 US model (1975)
Offline deltarider
Re: Gerben question
« Reply #8 on: December 17, 2019, 10:56:59 AM »
I agree with Erny. Things I'd do first:
A. Remove any inline fuel filters. They gave me nothing but trouble.
B. Make sure fuel tubes are exactly the right dimensions knowing:
18 and 30 cm when you have the old bowltype petcock or 17 and 28 cm with the newer style petcock. Don't be tempted to cut them even one cm longer 'to be on the safe side'. You will only increase the risk of kinking. Only the precise length can guarantee the right fuel flow. Ideal internal ⌀ is 5,5 mm, outside ⌀ will be 9-11 mm. Use the soft metal clamp front side carb rack to guide the tube to 3+4.
C. After a long period of inactivity float needles may tend to stick. Also the floats swivel pin may need some 'lubrification'. A fuel system cleaner like Redex can do that (some just add a few oz of kerosene). BTW, I have the feeling K3 owners cannot escape using this stuff on a regular basis. You could also remove the floatbowls to inspect for yourself and 'polish' float valve and needle and the swivel pin very lightly with something non abrasive. Usually the swivel pin can be removed with your thumb and forefinger. When you need pliers, make sure you do not pinch the pin. Careful, some have managed to break the towers.
Re: Gerben question
« Reply #9 on: December 17, 2019, 11:45:21 AM »
Ok I have bitten the bullet and ordered a Gerben set as he will give me £100 trade in for my old set
Decision is based on the fact that my carbs have just never really been right despite a number of strip downs replacement jets etc etc etc.
I recently switched back to another set of pilot jets which has just made it worse and am basically fed up with spending so much damn time trying one thin after another
I have checked fuel lines, petcock, float levels. There are deffo no air leaks and I have new rubbers and clamps etc and all is squeaky tight
Given how much more time I could spend messing about with yet more brassware, stripdown ....... I don’t think it’s a bad investment at around £220
If nothing else I will get a nice shiny set to fit that can only make the bike look better
Offline 10tenmen
  • A good old un.
Re: Gerben question
« Reply #10 on: December 17, 2019, 01:44:34 PM »
I got mine refurbished by Gerben for the 400/4 I had overflow issues and inability to reach top revs, they arrived back and went straight on and without any adjustment the bike was 100% better, I synced them with a set of vacuum gauges and they required only minor adjustment. Bergen had to replace the four slides and float bowls.
For me it was worth every penny
Re: Gerben question
« Reply #11 on: December 17, 2019, 01:51:06 PM »
Good to know👍👍
Re: Gerben question
« Reply #12 on: December 18, 2019, 07:49:38 AM »
You can also get these clamps from INOX fasteners in Southampton, found them to be a good source for fasteners
www.inoxbolt.co.uk/
« Last Edit: December 18, 2019, 07:54:43 AM by paulbaker1954 »
Re: Gerben question
« Reply #13 on: December 18, 2019, 08:28:37 AM »
The problem with jubilee clips is that they cut in to the rubber as you tighten them up and can cause leaks. The inside of the jubilee is serrated and drags across the rubber as you tighten .  A better option is Mikalor supra hose clamps which are smooth  ;)
Offline Menno
Re: Gerben question
« Reply #14 on: December 18, 2019, 10:07:41 PM »
Delty rider: 32 - 50 mm
