Author Topic: CB400F2 with different electrics?  (Read 2916 times)
Offline Athame57
« on: March 05, 2020, 02:51:06 AM »
I just saw the pictures for a really clean CB400F2 on ebay and noticed that the underseat picture was showing different electrics to my own, is this bike modified? See pic.
I brake for animals!
1978 CB400F2 named Elen.
Re: CB400F2 with different electrics?
« Reply #1 on: March 05, 2020, 06:33:55 AM »
May be a combined electronic reg/rec
Offline PatM
  • 2001 R1, Triumph 1200 and the little 400/4!
« Reply #2 on: March 05, 2020, 06:37:01 AM »
It looks like someones upgraded the rectifier with an aftermarket universal one. No reason why it wouldnt work ok as its only taking the a/c and converting it to DC to feed the electrics. It probably got better control over the output that the old one as the shunt-windings of the regulator on the OEM can be hit and miss after 40 years,  compared with a buck-converter Solid-state equivalent on a modern type.
Offline gtmdriver
« Reply #3 on: March 05, 2020, 08:34:47 AM »
I've fitted the Electrex world unit to my CB350F and it's working fine.
Offline Oggie400F
« Reply #4 on: March 05, 2020, 10:22:28 AM »
Could the blue box next to the regulator/rectifier be associated with an electronic ignition system?
It seems feasible that if the owner has upgraded the reg/rec  they will have also replaced the points with electronic ignition. 🤔
I'm a Radiographer............I can see right through you!!
1999 VFR800 fix in Pearl Prism Black
1978 CB750F1 in Candy Presto Red
1976 CB550F Supersport Brat Bike in Black
1976 CB400F in Varnish Blue - project bike in many bits.
