Author Topic: Brake switch  (Read 3361 times)
Offline Woodside
Brake switch
« on: April 01, 2020, 07:22:26 PM »
Is there an easy way to test the front brake switch on the 500.
It would be nice to know before I tidy it up and fit and fill the system
Thanks in advance
Re: Brake switch
« Reply #1 on: April 01, 2020, 09:01:22 PM »
Not easy without pressure only ever known 1 go wrong, and that was under Honda warantee
Offline Woodside
Re: Brake switch
« Reply #2 on: April 01, 2020, 10:26:33 PM »
Ok
Thing is
I have 3-4 here and all have been off a bike for at least 5 years if not 10+
So god knows what condition they are in.
Perhaps I will sort them all at least one must be ok
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Brake switch
« Reply #3 on: April 02, 2020, 01:04:47 PM »
... I guess the most obvious thing to do is to check each one is open circuit before you bother fitting it/them. (Ie if continuity is present in the dry / unpressurised state then it’s probably duff)
Online deltarider
Re: Brake switch
« Reply #4 on: April 02, 2020, 04:00:11 PM »
Re: Brake switch
« Reply #5 on: April 02, 2020, 04:22:07 PM »
All it sez in that is check continuity with lever pulled which means it has to be fitted and bled, that dont help to OP with which one to fit.
I have read on the US forum about somebody sticking a rod in the hole and pushing but i dont like that idea as it might damage the internals
