Author Topic: Battery charging without removing side panel  (Read 3169 times)
« on: April 11, 2020, 11:45:48 AM »
Lazy I know but Menno’s exquisite sidepanel will not come off with the normal amount of force.  Probably down to the new rubbers.
I can’t reach the positive terminal to charge the battery.
Where else could I connect it that’s accessible in a crowded garage.
« Last Edit: April 11, 2020, 11:54:05 AM by SteveD CB500K0 »
Re: Battery charging without removing side panel
« Reply #1 on: April 11, 2020, 11:52:15 AM »
Can you get the other panel off?
Try one of the leads on the starter solenoid
« Reply #2 on: April 11, 2020, 12:04:15 PM »
Red terminal at ignition switch Steve
« Reply #3 on: April 11, 2020, 12:28:41 PM »
Anything on the right hand side as the bike is up against the wall.
« Reply #4 on: April 11, 2020, 01:22:50 PM »
Turn jgnition on with kill switch off and connect to black wire at rear brakelight switch
