Author Topic: CB400F Ressurection - Cam Chain Adjuster Housing Damaged  (Read 6471 times)
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
Re: CB400F Ressurection - Cam Chain Adjuster Housing Damaged
« Reply #15 on: May 03, 2020, 02:18:02 PM »
I hear what you say.
Does anyone have any experience of these from Legend Motorcycles?
https://www.ebay.co.uk/itm/Honda-CB400f-Brand-New-Pair-Of-Fork-Tubes-1975-1977-Stanchions-400-4-400-four/113669408153?hash=item1a77398599:g:ZG8AAOSw18BceVFO
Another question. The mudguards – apart from the holes in the rear – and the chain guard clean up to an acceptable, for now, level. I’ve got most of the surface rust off using vinegar and a scotch pad.
If I could stop the flash rust turning them brown within 30 mins, I’d be content to use them. A coat of WD40 works to a point, but would obviously wash off. Anyone know of anything a bit more permanent?
Incidentally, I contacted IKON Suspension in USA – I got a great service from them when replacing my 750 suspension – and Nils there told me that spares for the 76 series Konis, predecessor to the 1076,  are not available. So it seems I need new shocks; the bump stop disintegrated completely when I was dismantling it.  :(
« Last Edit: May 03, 2020, 02:21:10 PM by SeanFD »
CB750 K2 - See: Belfast2BelfastByBike.com
CB450 K1 - A work in progress. (Still!)
Offline SeanFD
« Reply #16 on: May 05, 2020, 01:52:34 PM »
Has no-one any ideas on how to stop flash rusting on what’s left of the chrome on my mud and chain guards?
« Reply #17 on: May 05, 2020, 03:00:00 PM »
Wipe the chrome over with an oily rag.
Offline SPR
  • 1972 500/4 K1
« Reply #18 on: May 05, 2020, 04:40:33 PM »
ACF50 ?
Offline Golfcarmad
« Reply #19 on: May 06, 2020, 05:27:36 PM »
Not sure if my solution helps-but it was cheap and has worked:
A right mess of camshaft tensioner thread on outer casing.
So I tapped a new thread M8 dropped a ball bearing in crewed in bolt with lock nut-So now it’s more a manual adjustment but worked fine.
Hope this idea helps-you have nothing to lose trying it before you spend hundreds/new cases.
More bikes than sense!!
Honda 400/4 (almost fully rebuilt)
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Honda CBR500F (Import)
Francis Barnett Plover
Puch Maxi 2 speed (makes me smile)
Cb100n cafe racer
50cc scooter (now does 52 mph)
