Author Topic: Cb550k3 Rectifier  (Read 8029 times)
Cb550k3 Rectifier
« on: June 28, 2020, 05:57:45 PM »
Hi everybody, anybody cruising today? Went for a run just about 18miles switched to reserve fuel on my return to town so filled up, pushed starter button wouldn’t even turn over, thank god there’s a kick start lever. I came home checked voltage on battery 11.3 volts! Not good. No power whatsoever getting from alternator to battery. I have a suspect rectifier with a slightly fried red/white wire. Question is replace with just rectifier or replace with regulator rectifier. About the same cost wise from what I’ve seen so far.
Re: Cb550k3 Rectifier
« Reply #1 on: June 28, 2020, 06:48:40 PM »
Im old school and prefer original to this new fangled electonickery.
Rectifiers rately go a used one will 80% be OK.
Offline nairb
« Reply #2 on: June 28, 2020, 07:11:30 PM »
On my 3 phase Suzuki gt550 I use a rectifier from fleabay  for less than 3 quid.  My 550K3 still has the original rectifier so I have not had to change it but it has the same wiring as the suzuki.  3 yellow 1 green and the Red/white?.  Well the suzuki is just red.  I have these fitted to all of the suzuki bikes and in 10 or so years not one has failed.
Its been a very cheap option.  Fleabay item search Sql35a
« Last Edit: June 28, 2020, 08:11:39 PM by nairb »
cb550k3, cl450k5, re5m, xs650xs2, mt500, kettle, gt550 x2, gt380 Kz750 twin, cb360K0 and an old working bicycle
« Reply #3 on: June 28, 2020, 07:33:08 PM »
Thanks very much guys, that rectifier looks very interesting, anybody else tried one? I think at that sort of money you can’t go wrong. Seen a couple on dk spares but everything advertised 39.99 postage and they don’t use Royal Mail which is cheapest for sending to Orkney, especially something that can be slipped into a small Jiffy bag.
Offline cliff7
« Reply #4 on: June 28, 2020, 08:32:05 PM »
I fitted a similar one only a 50A one as it had built in heat sink fins (about a fiver) to a CB400F and it seems fine so far.
« Reply #5 on: July 04, 2020, 04:09:37 PM »
Fitted today, all seems fine, too wet for road test but passed garage run testing.
« Reply #6 on: July 04, 2020, 05:49:10 PM »
Also to add to the discussion pot  http://forums.sohc4.net/index.php/topic,183347.0.html interesting related thread over on the USA sohc site that could be of interest.
Online SteveD CB500K0
Cb550k3 Rectifier
« Reply #7 on: July 04, 2020, 07:19:52 PM »
That tie-wrap needs to be black Jonny
« Reply #8 on: July 04, 2020, 07:30:38 PM »
Your absolutely right just doesn’t look right! Quick get the side cover on before anybody else notices.😂😂
« Reply #9 on: July 04, 2020, 08:41:21 PM »
Them there’s the white heat shrink…
« Reply #10 on: July 04, 2020, 09:21:35 PM »
Thought I did well finding bits and pieces of correct colour wire, unfortunately no green heat shrink. Added to shopping list  along with black cable ties!!
Offline mike the bike
« Reply #11 on: July 04, 2020, 09:44:56 PM »
My 400 ground to a halt on the M4 due to a lack of volts.  One of the terminals had broken off the rectitifer  flush with the epoxy potting.  I  sharpened up a screwdriver and chiselled some of the epoxy away from the broken terminal so I was able to solder a new spade onto it.  That was about 7000 miles ago.
« Reply #12 on: July 05, 2020, 07:47:55 AM »
Good fix Mike! Was that a similar type rectifier? Wasn’t sure of the durability of these cheapo components. The temptation to spend £4 compared to £60 was overwhelming.😂
« Reply #13 on: July 05, 2020, 08:57:23 AM »
Mine was the standard Honda item.  The difference between the OEM one and what you've got is, maybe,  the heatsink.   Yours might run a bit too hot and break down.  You can always add a heatsink to it if you think it's inadequate.  With a smidge of heatsink paste.
« Reply #14 on: July 05, 2020, 11:42:44 AM »
Thanks for that I did wonder about the heat side of it. I will keep an eye on it after a couple of longer runs, I will probably replace at some point with the correct item in keeping with the bike spec. (he says with his electronic ignition)🤫
