Author Topic: Tap n die set recommendations  (Read 71056 times)
Offline WestYorkshireBiker
« on: June 30, 2020, 10:55:00 AM »
Looking for a good quality tap n die set and don't want to get cheap eBay crap. Also what sets are needed for Honda's as I've read there's some JIS threads which have a different pitch to normal metric? The bike I'm getting I know for a fact has a broken head bolt so need help getting the right gear chaps. Thanks.
Sent from my ONEPLUS A6013 using Tapatalk
OW MUCH????????????
Re: Tap n die set recommendations
« Reply #1 on: June 30, 2020, 11:06:28 AM »
Honda used some non prefered pitch threads, but still standard, in some places.
In all honesty i would buy just the sizes you need as some will need repair so you need helicoil kits anyway.
Most used size would be 6 x 1 and if its just a repair a plug tap will do but to tap a blind hole you need a taper first.
Tell me what you want to repair and ill tell you what sizes you need
« Reply #2 on: June 30, 2020, 11:10:11 AM »
Thanks. I don't have the bike yet but I'm getting some tools etc bought so I'll probably just get a standard set and buy what I need when I need it I guess. It's more what decent makes to look for tbh. Amazon and eBay recommendations seem to vary on whatever I look at.
OW MUCH????????????
« Reply #3 on: June 30, 2020, 11:10:59 AM »
If you want a selection of taps and dies Tracy Tools have some for £20. You can also call them for a chat to discuss exactly what you need. They have been around for years and are a reccomended source of quality engineering taps and dies. I've used them many times and never had a problem with the quality of their tools.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwikiOqIpanqAhUsQhUIHc5LDjQQFjAAegQIARAD&url=https%3A%2F%2Fwww.tracytools.com%2F&usg=AOvVaw0SKoLqgxcwMYaqtZpNffdU
« Reply #4 on: June 30, 2020, 11:15:14 AM »
Perfect. Thanks Dave.
OW MUCH????????????
Offline mickwinf
« Reply #5 on: June 30, 2020, 12:36:48 PM »
I have a set from Aldi, works well for occasional use. One thing to watch for is the 10mm size as most sets have a 1.5 thread pitch and hondas use a 1.25 fine pitch. As Laverda Dave said, tracy tools very good for this type of thing
« Reply #6 on: June 30, 2020, 12:50:54 PM »
General recommendation to go with the tools mentioned above
 https://www.bearingboys.co.uk/Rocol/Rocol-RTD-Compound-50g-53020-167584-p?gclid=EAIaIQobChMI2aeDvrqp6gIVQ-7tCh2-BwBgEAQYAiABEgL3PvD_BwE
Still the finest thread cutting lubricant known to man  ;D ;D ;D
Makes the best thread finish,  refined cut and least "oversize" final threads by reducing tool drag during use. Well worthwhile.
Offline Phil Ward (RIP)
« Reply #7 on: June 30, 2020, 12:58:15 PM »
« Reply #8 on: June 30, 2020, 01:39:55 PM »
When we get back to "normal" a good idea is to rumage at autojumbles, steam fairs etc so you get a day out and buy quality stuff Presto is a good name
Offline sprinta
« Reply #9 on: June 30, 2020, 02:09:53 PM »
Offline ka-ja
  • ken
  • yoshi 460
« Reply #10 on: June 30, 2020, 02:22:30 PM »
For drills and taps etc. Dormer and Warrior and SKS used to be the bees knees.
nice bike,nothing in the bank
« Reply #11 on: June 30, 2020, 05:14:24 PM »
I have this set. Not cheap, but will last me a lifetime...
Laser 4554 Metric Tap & Die Set 110pc https://www.amazon.co.uk/dp/B002TW7GE0/ref=cm_sw_r_cp_api_i_ft2-EbHFJYJ7C
Offline davefirestorm
« Reply #12 on: June 30, 2020, 06:07:23 PM »
I’d invest in a thread gauge to determine the pitch of threads (you will possibly find 10mm bolts in 1.00,1.25,1.5 pitches) then just buy the taps/dies you need and buy quality  not cheap tat from China😁 I look for them at Autojumbles but make sure they’re not chipped/blunt had most of mine for years Dormer,Presto,SKF good makes and as stated look for HSS.
« Last Edit: June 30, 2020, 06:16:45 PM by davefirestorm »
Honda CB650Z
Honda F6C Valkyrie
Offline SumpMagnet
« Reply #13 on: June 30, 2020, 06:25:43 PM »
I shop from here:
https://www.tracytools.com/taps-and-dies
I started with a basic cheap and nasty set...but soon saw the limitations and staterted buying quality taps for the threads I used a lot.
cheap onews don;t cut clean threads, and you really will notice the difference
CB750F2 - in pieces
« Reply #14 on: June 30, 2020, 06:37:06 PM »
Also invest in some decent tapping oil/grease I use Trefolex it smells lovely😁
Honda CB650Z
Honda F6C Valkyrie
