Author Topic: New E10/5 fuel  (Read 16657 times)
Re: New E10/5 fuel
« Reply #15 on: August 11, 2020, 12:05:11 AM »
Personally I avoid regular fuel like the plague.... premium fuel for your classic is the easiest way to avoid 10% ethanol.....for the time being at least.
Me I only buy Super Unleaded as I always do until they fiddle with that as well. Apparently there is a loss of economy using E10 so it seems an odd way to reduce emissions.
« Last Edit: August 13, 2020, 09:02:21 PM by Macabethiele »
Offline jshonda
Re: New E10/5 fuel
« Reply #16 on: August 30, 2020, 06:54:00 PM »
Ethanol has a higher octane rating than petrol, it burns cooler and completely, as it is an 'oxygenate' (the fuel contains oxygen molecules.). It also has a lower energy content, around 30% less than petrol, and it should make an engine run more smoothly, but slower and do fewer mpg.
Good for destroying rubber components in the fuel system, especially old bikes!
Ethanol is cheaper to produce than petrol, but we never see reduce prices at the pump!
Offline Skoti
Re: New E10/5 fuel
« Reply #17 on: August 31, 2020, 12:39:21 PM »
As far as fuel hose goes I find that the only stuff that seems to be ethanol proof is the genuine Honda stuff that DS sells.
It's also the correct inside diameter of 5.5mm for our bikes and has the right wall thickness to prevent kinking when routing around the carbs etc.
It's not cheap though.
https://www.davidsilverspares.com/950015500160M
The same stuff is standard fitment on my Honda lawn tractor, which I suppose is intended to be ethanol proof for todays fuel.
Hope this helps
Regards
Skoti
« Last Edit: September 01, 2020, 09:04:17 AM by Skoti »
Skoti
1976 Honda CB750F1
Re: New E10/5 fuel
« Reply #18 on: August 31, 2020, 01:09:30 PM »
All the pipe we buy from Planet Silicone holds up very well to modern fuels and its really cheap from them. We have also been upgrading all O rings in the carbs to Viton for a long time now and no problems there either.
« Last Edit: August 31, 2020, 01:12:07 PM by Nurse Julie »
Offline Skoti
Re: New E10/5 fuel
« Reply #19 on: September 01, 2020, 09:14:47 AM »
Hi Julie,
thanks for posting the tip regarding cheaper fuel hose and carb viton 0 rings.
I previously tried 6mm silicone/neoprene based hose from Louis Motorrad (which wasn't cheap) but is was supposed to be ethanol proof.
After a couple of years it turned rock hard and I had to cut it off the fuel tap fitting with a stanley knife.
Turned out that it was only rated for use up to temps of 100°c.  I've noticed it's no longer stocked by Louis.
Do you have a supplier for the correct size viton 0 rings for the float bowl drain plugs?
regards
Skoti
« Last Edit: September 01, 2020, 10:16:24 AM by Skoti »
Skoti
1976 Honda CB750F1
Re: New E10/5 fuel
« Reply #20 on: September 01, 2020, 09:24:58 AM »
Hi Skoti. I hold stock of Viton O rings for the drain plugs, but if you are wanting them for your 750 F2 I'm not sure if they are the same size as all the other drain plugs. Do you know the size? PM me if you wish.
Should have said, if its a F1, I have definitely got stock of the correct size.
« Last Edit: September 01, 2020, 09:38:30 AM by Nurse Julie »
