Author Topic: Wiring diagram for CB175 (K6)  (Read 6973 times)
« on: August 17, 2009, 08:19:09 AM »
Trying to fault-find this with a strange earthing problem.
Park light and rear light don't work - can't find the feed anywhere.
Indicators flash at 2x normal rate and stop if the headlamp unit is screwed back onto the shell.
This bike has an external switch on the headlamp shell for the lights, together with a main beam indicator lamp set into the top of the shell. I'm assuming that this isn't standard (?)
My CB175 was a K4 and it was 1976 so I don't really remember the setup of the light switches...   8)
Re: Wiring diagram for CB175 (K6)
« Reply #1 on: August 18, 2009, 04:08:31 AM »
As I remember it Steve the set up was very similar to the 500 as far as switchgear went but i do believe there was a main beam light in the headlamp shell
« Reply #2 on: August 18, 2009, 08:49:56 AM »
I've had a confirmation from HOC that they did indeed have a headlamp shell switch (off - park - on) with a L - H switch on the right hand bar.
« Reply #3 on: August 18, 2009, 05:32:22 PM »
Well it has been a long time and copious amounts of Guiness since i saw one Steve
