Author Topic: CB500 Alternator  (Read 6764 times)
Offline masonmart
CB500 Alternator
« on: August 23, 2020, 08:25:52 PM »
Having finished my Dresda CB500 and registered it I've at last had chance to run it. It ran like a dream but the battery flattened so no charge. It had been left outside for 40+years so my guess it is the alternator but not my area of expertise. A quick look around seems to show that they are rare or, if NOS, very expensive. Can anybody advise on possible solutions like aftermarket parts, rewinding or anything else I may be able to look at?
Many thanks.
Dresda CB500-4, 605 cc
CB-77, 350 cc
1968 Bonneville
1976 Thruxton Velocette
1974 Kawasaki Avenger
1997 VFR 750
Offline robvangulik
  • Honda Fourever
Re: CB500 Alternator
« Reply #1 on: August 23, 2020, 09:19:57 PM »
I would first recharge that battery and then measure what the voltage does with the bike running, before ordering possibly unnecessary parts. Alternators rarely go wrong, other than by throwing them on the street with force.
Measure first, buy later!
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #2 on: August 24, 2020, 02:26:02 AM »
Hi Masonmart,
Don’t be too quick to bin your alternator; there’s no moving parts in it, and given a multitude of other components in the charging system the culprit likely lies elsewhere.
You can however, easily check it, accepting that if you hate electrics you may need some help... (and definitely a multimeter - which can be easily got for £10 upwards)
Before you junk it then, check the continuity of the various wires, as basically it’s made up of windings ... which are either broke, shorted, or likely fine.
1st up disconnect the alternator loom plug; which’ll have a GREEN, WHITE (= Field Coil), 3x YELLOWS (= Stator Coils) and possibly a couple of others ... which may be Oil Px & Neutral feeds (uncertain of the 500). Poke your multimeter probes into the various connectors on the Alternator side of the disconnected  plug...
The STATOR winding has the 3 YELLOW Wires. Measure the resistance (Ohms scale ♎️) between each of the Yellow wires. (No need to worry about which way ‘round the Red/ Black leads go). You should see a reading of 0.61-0.69 ohms for each measurement.
The FIELD COIL has two leads... the GREEN and a WHITE. (Again, same Ohms scale, and no need to worry about Red/Black leads), measure the resistance - should be 4.6 to 5 ohms.
It goes without saying that these bikes and their looms are rather old, and all bullet connectors must be clean & tight. You really need to check the connectors throughout the charging system... ie include the regulator, rectifier, fuse holder blah blah.
NOTE ‘500 owners! - help required with quoted resistances as I’ve used the 400F numbers which I assume to be the same. Please chip in if different....
Good luck,
Simon
(Alternator whole shown in Red box, Stator windings in Green box, and field coil in a Blue box.
« Last Edit: August 24, 2020, 02:37:29 AM by Lobo »
« Reply #3 on: August 24, 2020, 05:57:27 AM »
I have never seen a bad field coil and only stator coils physicaly damaged in accident.
95% of problems are caused by poor or high resistance connections and/or switches, 4% by broken wires and the othe 1% rectifier or regulator.
I did do a testing procedure which was in tricks and tips
« Reply #4 on: August 24, 2020, 08:55:00 AM »
Main problem I have seen on 400 &500/550 stators (that run dry and  not in oil like Honda twins) is a breakdown of the insulating coating of the copper magnet wire probably due to corrosion of the stator steel laminations. The quick test for this is , with the three yellow output wires disconnected from the sub-loom there should infinite resistance (i.e open circuit) to the mag. frame steel  laminations. If there is any lowish resistance (say less than 100k Ohms), then the stator is usually toast. I had this on two 400/4 stators on the four 400/4's I owned 'back in the day' and when the bikes were less than 10 years old. They are very  complicated to rewind so a good used one is probably the cheapest repair option.
Offline masonmart
« Reply #5 on: September 07, 2020, 09:03:13 AM »
Many thanks for the tips gents. I'm going to have to educate myself on how to test electrical devices and I probably need to start with a wiring diagram as the electrical system is completely non-standard. The engine had been crashed at one time too so damage to the alternator may be a possibility.
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
Offline masonmart
« Reply #6 on: November 05, 2020, 11:41:51 AM »
The problem was I fitted the wrong Regulator. It needs one with a positive lead back to the alternator and I got one without the lead. Bought the right one from Electrex and it charges well.
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
Offline Topcat
« Reply #7 on: November 06, 2020, 10:01:08 AM »
Hi All,
On this note I do believe in have a problem with a cb550 field coil, specifically broken wires going in to it. it had been clearly sitting in water for some time or water at least pooling in that cover and it's eaten away at the base of the wires of the coil and also eaten away at the magnet section on the bottom of the stator. I'd be interested in whether alternatives can be had for these bikes if only because I'm unlikely to be able to repair as the remaining non broken wire going into the field coil is in such bad condition.
I am looking at a few on ebay but just wondered what the option was for alternatives.
Topcat
« Reply #8 on: November 06, 2020, 05:45:48 PM »
Basically there isnt one
