Author Topic: Engine full of fuel and seized up  (Read 83096 times)
Re: Engine full of fuel and seized up
« Reply #15 on: August 30, 2020, 03:50:56 PM »
IF it has bent a rod,  then it's better to leave in without significant force applied to avoid additional complications I suppose.
Detecting accurately without internal inspection may be difficult,  at least I can't immediately think of a competent way  :)
It takes only a small amount of fluid (anything much above tdc combustion chamber volumes) to compromise a rod.  It's even more effective with less total volume error above chamber volume as the crank can build more approach speed until it meets resistance,  and finally tweak the rod as it won't go over compression.
Vaguely better news ( again,  if this is the cause) is that it may be only one piston as it's pair cylinder would have valves open at the same point. If that's the case,  then damage may be very minor with just one piston cocked side ways and locking the crank.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #16 on: August 30, 2020, 10:53:06 PM »
I’ve thankfully little experience of bent conrods - but would an accurate measurement down the top of the bores (ie through the spark plug hole) show up a difference between two companion pistons?
That’s said perhaps a waste of time as this does sound to be a head off. Feeling bad for you PJM47..., and kinda wondering why we don’t hear more of such failures given the number of CBs out there...
« Reply #17 on: August 31, 2020, 11:18:35 AM »
Commiserations for your loss.
My wife, acting as designated driver on the way home from a bike club ‘do’, once drowned my 2.8 V6 Capri, by driving it through a flood. The air intake was quite low down, next to the headlights behind the front grille.  We got out, getting us and the interior very wet, and pushed it to safety, then idiot here decided to try and bump start the car. No joy, it wouldn’t turn over,  and the next day when I took the plugs out, jets of water shot out of the plug holes as I cranked the engine.
I got it running again, but with a loud death rattle, which turned out to be displaced main bearing shells if I remember correctly. I do know I had to pay a shedload of money to have it fixed.
Offline PJM47
« Reply #18 on: August 31, 2020, 11:29:03 AM »
Thanks for all the replies an sympathy :) It was only turned over a few times on the starter so maybe damage isn't too severe. Every part was completely full of fuel though. Anyone have an idea of how much an engine strip and rebuild would be or would i be better of looking for a complete replacement engine?
« Reply #19 on: August 31, 2020, 12:13:18 PM »
Always take it apart and asses what is needed first, you may not need as much as you think you may need more and a used engine is an even worse unknown quantity---pay a fortune and get crap!!
Offline rosco
« Reply #20 on: August 31, 2020, 05:02:07 PM »
Have you thought it could be the gearbox stuck???  My brother bought a cb550 with a "seized engine " Turned out something in the gearbox let loose [ can't remember what ] and jammed the gears and broke a few teeth Try pulling in the clutch  and using the kickstart  If the kickstart don't move its the gearbox If it does move more than likely engine  Good luck   R
« Reply #21 on: August 31, 2020, 05:39:48 PM »
For what it's worth I think I would take the clutch plates out and try and gently turn the crank with a spanner on the timing end. It's going to be tight as it will have washed every bit of lubrication out on the engine. Oil pump strip required at the very least. Starting it now with petrol washed through the bearings would be a big risk that could cost a crank. Only real safe route is an engine strip.
« Reply #22 on: August 31, 2020, 05:47:00 PM »
DO NOT TURN THE CRANK AT THE TIMING END
If you try you will wreck the advance unit. If you want to try turning the crank remove the generator cover and try on the big bolt holding the alternator rotor
« Reply #23 on: August 31, 2020, 05:59:37 PM »
Why would you wreck the timing unit, that's how you get tdc to set your timing? I'm not meaning to put a drill on it and spin it up at a 1000rpm, just a few very gentle mm's with the big keyed to the crank special nut (as Honda Calls it). Or have I lost the plot again. LOL.
« Last Edit: August 31, 2020, 06:59:02 PM by royhall »
Offline PJM47
« Reply #24 on: August 31, 2020, 06:58:45 PM »
So in neutral with clutch held in the kickstart still won’t move. Does this mean more likely a gear box problem? I can select neutral and gears ok.
« Reply #25 on: August 31, 2020, 07:35:33 PM »
It doesn't turn on the starter either I thought.
Kickstart essentially bypasses the gearbox on these by just going down through the primary chain to the crankshaft, hence you  can pull the clutch and start it whether it's in gear or not.
« Reply #26 on: August 31, 2020, 11:36:32 PM »
The only thing holding the advancer in time with the crank is a solid small dowel pin, if you put a lot of torque on the big nut you will snap off the ears on the advance cam, if you put too much torque on the 6mm stud you will snap it off.
It is only permissible to use that big nut with plugs out on a free turnung engine and its not really advised even then
« Reply #27 on: September 01, 2020, 07:14:48 AM »
As always Bryan you are correct, that was me thinking out loud. I have made the incorrect assumption that everybody works like I do. By that I mean when I do anything on a bike if it wont turn or assemble correctly I assume there's something assembled wrongly, broken, or I am doing something wrong. I therefore never ever use force on anything without first appraising the situation as that usually just makes things worse.
I should make it clear now that I used the words gently and very gently and only millimetre movements. It was not my intention to use the timing end it break the engine free with a scaffold pole, just to establish which part of the engine is locked.
It may be wise to establish the facts here. Firstly what level of mechanical competence does PJM47 have, I assume as he's talking about repair engineers he's not a professional. Are you a competent DIY mechanic or a complete novice or somewhere in between. Was the bike left on the side or main stands? On the main stand the leak would fill the airbox first as the intake side is slightly lower (on the F2 anyway). If it cannot escape from the airbox as the petrol level rose it would then fill all 4 cylinders via the airbox. The cylinder with two closed valves would hold fuel in the intake so when the engine turns that fuel gets drawn into the cylinder and before it can leak down past the rings the engine comes back to compression and bends a rod or tips a piston jamming it into the bore.
Also, just how much petrol are we talking about here, you appear to say it could be around 2 to 3 gallons sat in there over a good few weeks? With the limited space inside a CB750 engine that is enough to fill the thing from top to bottom. If that is the case, a complete strip and rebuild is the only way forwards. The fuel will be in all the bearings, oil pump, oil galleries, alternator, clutch, scavenge lines, oil filter etc etc. Even if you can achieve turning the engine again it would require careful work to safely run it again. If there's fuel in the oil galleries clean oil would need to be slowly pumped through the engine to re-lubricate everything with the sump plug out to drain the fuel pushed through. You would need to remove the scavenge line to the oil tank to prevent fuel contaminating the oil in the tank. And don't forget were also talking Ethanol here that loves to remove lubricating oil.
In my view this engine needs stripping to clean everything out and re-lubricate everything and locate the damage. The alternator needs cleaning and drying off and testing. I many years ago foolishly cleaned some clutch plates off a Suzuki in petrol and the corks grew to about twice the thickness they should be which cost me a clutch, so that will need checking. Then lets not forget the failure in the carbs that allowed this to happen that also needs sorting, plus the airbox will be full of fuel.
If it were me I would take out the clutch plates to disconnect the engine from the gearbox physically then put the bike in gear and gently turn the back wheel and see if the clutch inner turns. That verifies the gearbox is not locked and it's therefore in the engine/kickstart mechanism. At that point see if the engine turns (please do this very gently). But that only establishes the area the damage lies and the engine will need stripping anyway.
Sorry to be the bearer of bad news and I do sympathise whole heartedly with you. But if the bike was mine I would bite the bullet and get the engine out. It's a big price to pay for forgetting to turn off the fuel tap, and not one of us on here can say we have never done that, we just got away with it.
« Last Edit: September 01, 2020, 07:22:54 AM by royhall »
Offline PJM47
« Reply #28 on: September 01, 2020, 06:03:17 PM »
I’ve taken the clutch out and the rear wheel/clutch inner turns ok when in gear. Kickstart still won’t move. Like you say no point forcing anything, if it wasn’t broken it would turn easily with the plugs out.
I’m a fairly competent diy mechanic and will tackle most jobs but obviously this is pretty major and might be best left to a professional, ouch!
Offline rosco
« Reply #29 on: September 01, 2020, 06:19:48 PM »
If your looking for a pro to rebuild your engine  "Trigger " on this forum is your man and Julie makes nice Tea!!!!
