Author Topic: Engine full of fuel and seized up  (Read 83148 times)
Offline Phil Ward (RIP)
Re: Engine full of fuel and seized up
« Reply #240 on: November 18, 2020, 08:40:09 AM »
That's one lovely looking, well engineered car! Always preferred the looks of the Dax over the other Lotus 7 styled cars
Offline allankelly1
« Reply #241 on: November 18, 2020, 10:45:16 AM »
Yes
Always loved  the more purposeful look of the Dax Rush
Took some time to build and started with the engine first which took a year to build and cost in excess of 6k by itself as it was built on a brand new short block and it had lots of one off bespoke parts made by myself like  the thermostat housing and a one off pulley set
Then once engine / box was built then bought the kit and again spent again a small fortune
Was sorry to see her go and had a tear in my eye but replaced the empty space in the garage with motorbikes instead as you got to have something to tinker with
Offline PJM47
« Reply #242 on: November 18, 2020, 05:25:02 PM »
That looks excellent.
I took the oil filter off and oil soon started coming out. Put it back on and within a few seconds oil came out at the top end and then all over my bench and the floor as I hadn’t noticed it was working. Not sure whether taking oil filter out and back in helped or just coincidence but it’s working now so all good.
« Reply #243 on: November 18, 2020, 09:46:22 PM »
Good news then  :) it's always a little concerning and nervous time if you don't see it coming up as expected.
The bleed through, I suppose it's logical in that the system when closed with filter housing in place will run at 60psi with oil in it. So resistance to pumping the oil supply against air pressure may be just sufficient enough to prevent the oil filling the pump head (classic air lock) with the pump unable to draw oil through by trying to pump air,  if that makes sense.
In reality,  with the filter off and if the oil was warmer it would in all probability nearly run through there under gravity.
Nevertheless, it's the earliest point you can check for oil pump output to see if it's really pumping anything,  and easy to do to. As you found,  once the pump is going the rest will fill quite quickly.
Offline PJM47
« Reply #244 on: November 18, 2020, 10:02:45 PM »
Yeah makes sense, might be worth noting as a possible trick if anyone is having trouble in the future, especially as it’s an easy thing to try.
Offline PJM47
« Reply #245 on: November 28, 2020, 05:29:32 PM »
Just to finish this one off, engine is back in and running beautifully! Sounds really good, think it needed an overhaul anyway.
I replaced all the carb float needles and seats and overflow pipes to fix the original problem.
Many thanks for everyone’s help along the way.
Paul
« Reply #246 on: November 28, 2020, 06:09:16 PM »
Best wishes. Glad it turned out.
Enjoy it when you can
« Reply #247 on: November 28, 2020, 07:55:42 PM »
Great news. It's been a good thread to read, you have a sweet running engine and we have all learnt a lot. Well done.
« Reply #248 on: November 28, 2020, 09:10:42 PM »
Paul
Good to hear its sorted Paul
« Reply #249 on: November 28, 2020, 09:24:29 PM »
Nice one. Glad to hear it's a sweet runner now. Don't forget to turn the petrol off.
