Author Topic: 750 K2 Left hand switchblock UK version.  (Read 2016 times)
Offline Old Moe Toe
« on: September 25, 2020, 10:19:44 AM »
Hello.
Pretty new here.
I am looking to get a new wiring loom for my 750K2.
I seem to have some sort of export model in regards to the left hand switch gear.
Instead of just a round horn button this one has square combined horn/pass button and therefore has 6 wires exiting the switchblock (I think this may be the UK,France, export version of that switch) compared to 4 wires of the US etc versions and all the ones I have seen in Austtralia ,that had a round horn button.
I reckon the wiring looms must be different to suit the 2 different types, but talking to DSS they did not seem to know.
So the big question here is, Who knows which wiring loom is the right one to suit a left hand switch block that is like this(see pic)for a 72K2 750?.
Thank you and cheers from the other side of the planet.
Re: 750 K2 Left hand switchblock UK version.
« Reply #1 on: September 25, 2020, 10:40:53 AM »
That's similar to what we have fitted to our UK model CB750/4 K2's Brad.
« Last Edit: September 25, 2020, 10:42:34 AM by Nurse Julie »
Offline Old Moe Toe
« Reply #2 on: September 25, 2020, 12:41:29 PM »
Sure does Julie. Exactly the same. Thank you.
Has anyone with one of these switchblocks bought a wiring loom from DSS part number DCBAA-341_000P and found it has all the right connections to suit.
Asking because the wiring loom is the same part number as US/Aussie  models that have single round horn button only.
« Reply #3 on: September 25, 2020, 09:03:43 PM »
The looms are all the same just sometimes there is an extra jumper wire and the way the horn button works can vary.
1 horn has power and the other terminal is grounded by button
2 horn has ground and other terminal supplied with power from button.
Easy to switch over , you just need a multimeter and know how to use it to sort out switch
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #4 on: September 27, 2020, 09:41:35 AM »
I sympathise; my LHS has turn signal, horn/PA, and Hi/Lo buttons with 9 wires. On the RHS I have start and headlight Off/Lo/Hi switches with 7 wires.
With some jiggling I have managed to sort it out. I won’t bore you with the details, but I can now have HL off (Off), HL on (Lo) or pilot light only on (Hi). Not original, but ... well maybe it is original  ;D
However, that aside, during my researches - note the plural; it was a long process - I came across the attached partial wiring diagram which is allegedly for 1972 UK CB570K2/CB500 models.
It does have the correct wiring for your switch, if that helps.
