Author Topic: Oops or **** it! Rear wheel re-spoke update  (Read 6723 times)
Offline AndyD
Re: Oops or **** it! Rear wheel re-spoke update
« Reply #15 on: October 07, 2020, 01:08:43 PM »
Bill,
Hope the new ones work better!
Fingers crossed for you.
Be keen to see how you get on as I'll need to sort mine out a bit sharpish as well.
Cheers,
Andy
Offline billdn
« Reply #16 on: October 09, 2020, 05:36:35 PM »
Andy
New rims are DID and what a difference in quality !!!!
Just got to undo the duff ones now and start again! :-\ :-\
Online Nurse Julie
« Reply #17 on: October 09, 2020, 05:42:10 PM »
Andy
Well done Bill. The DID's are great rims.
Offline philward
« Reply #18 on: October 09, 2020, 08:12:17 PM »
Good to hear as I'm just waiting for a set to arrive for my 500 myself
Offline AndyD
« Reply #19 on: October 10, 2020, 11:59:16 AM »
Good stuff Bill
Makes a bit of a mockery of the DSS description of the Takasago ones as "no compromise on quality" !!
I'll give them a call next day or two as the front DID rim is still showing out of stock.
Cheers,
Andy
Offline waffey
« Reply #20 on: October 13, 2020, 09:15:47 PM »
sorry to jump in as well. I'm looking to rebuild my rear wheel soon.
I used the front wheel rim and spokes from WEMOTO. Quality seems to be good but they dont have the rear.
r
Is it only DSS that have stock ear rims or can I source them else where?
Bikes:
Triumph Street Twin
Suzuki Address 110 Scooter
Suzuki TL1000s
BMW R1200GS LC
Honda CB400 F2 1977 (restoration underway)
Offline billdn
« Reply #21 on: October 16, 2020, 10:08:30 AM »
Well that was easier with the DID rim than the other ones, I've managed to get around 1mm run out on the lateral (side to side ) which I feel is acceptable but I'm not sure on the radial -currently about 1mm measured with a feeler gauge between pointer and rim edge- looks okay to me but should it be lower.?
« Reply #22 on: October 16, 2020, 10:35:42 AM »
I think that's within tolerance, but try and get it closer if you can.
« Reply #23 on: October 16, 2020, 02:02:13 PM »
Honda's (and mot) tolerance is 3mm for each
Offline billdn
« Reply #24 on: October 16, 2020, 06:19:29 PM »
BryanJ - thanks for that, well under 3mm which does seem an awful lot but finished at 1.5mm for both so good enough for Jazz :)
