CB750
Now, how did that get in there?
Topic: Now, how did that get in there? (Read 3547 times)
Johnny4428
October 25, 2020, 08:02:21 PM »
I’m not convinced that found its way in there when I removed generator and cover.
K2-K6
Re: Now, how did that get in there?
October 25, 2020, 08:28:00 PM »
Looks like the washer from the gearshaft idler that the starter motor drives.
Johnny4428
October 25, 2020, 08:46:15 PM »
Yes your right! Didn’t know when I first opened it up but got it out with magnet then looked up parts list. Is it possible for that to slip behind the starter pinion when removing cover?
Phil Ward (RIP)
October 25, 2020, 08:59:02 PM »
Its defo as k2-k6 suggests - and may have fallen down as you removed the shaft that holds the idler gear
K2-K6
October 25, 2020, 09:07:02 PM »
Yes it will slip out if not careful.
The shaft is just floating and retained by the cover preventing it moving, if it's pulled out as you withdraw the cover then the washer can just drop off.
Johnny4428
October 25, 2020, 09:44:57 PM »
Does the washer go between idler and cover?
Trigger
Engines built on reputation, not advertising.
October 25, 2020, 10:38:29 PM »
Yes, it is to stop the cog rubbing the alternator housing
Johnny4428
October 26, 2020, 06:16:34 AM »
Thanks Trigger.
SeanFD
SOHC Expert
"Still running against the wind"
December 06, 2020, 09:25:40 PM »
I asked exactly the same question once ...
CB750 K2 - See: Belfast2BelfastByBike.com
CB450 K1 - A work in progress. (Still!)
Johnny4428
December 07, 2020, 09:00:08 PM »
Holy shit Sean! Surely not with the float bowls on.
SeanFD
SOHC Expert
Reply #10 on:
December 08, 2020, 10:55:27 AM »
Yep. And at leat 500km done.
Johnny4428
Reply #11 on:
December 08, 2020, 08:41:54 PM »
Looks like it has been curled round the float valve pin.
CB750
