CB350/400
Speedo knob
Topic: Speedo knob (Read 3179 times)
AndyD
SOHC Expert
Speedo knob
October 26, 2020, 08:01:17 AM »
No, not a reference to a bizarre retro swimming trunk ailment!
I wondered how the trip meter knob is removed on the speedo?
Also, can the rubber cover on this be replaced without opening the clocks (assuming the rubber bit is available)?
Cheers,
Andy
allankelly1
SOHC Expert
Re: Speedo knob
October 26, 2020, 03:28:17 PM »
Hi Andy
These guys do the grommet and lots of other gauge spares
Used them when I was sourcing new glasses and decals for my gauge rebuild
Best wishes Al
AndyD
SOHC Expert
Re: Speedo knob
October 26, 2020, 03:41:18 PM »
Thanks Al,
I'll have a look on their site now.
Do you know hoe the knob is removed as well by chance?
Cheers,
Andy
allankelly1
SOHC Expert
Re: Speedo knob
October 26, 2020, 03:47:22 PM »
Hi Andy
No sorry I don’t
My one was in a real bad state so just cut it off the shaft and made a new one on the lathe as was not after an “original restoration†but something a bit different
But if you look at my picture the end has a straight knurled it my just be a press on fit but no doubt somebody will be along to confirm
taysidedragon
Re: Speedo knob
October 26, 2020, 03:56:41 PM »
The trip knob is just pressed on the shaft but very hard to budge. I managed to get mine off but it was a bit distorted in the process. It's probably easier to cut it off and replace it. Some caps on tubes of glue are almost exactly the same size and can be filled and drilled to fit.
The rubber can be replaced from the outside but easier to do if the speedo is opened.
AndyD
SOHC Expert
Re: Speedo knob
October 26, 2020, 06:32:53 PM »
Thanks guys,
Think I'll order a rubber cover and see if it can be wiggled over the trip knob without removing it as it sounds like it's risky removing it.
Have an old speedo to play with first so that should help.
Just a small tear in the cover but it will annoy me if I don't al least try and fix it!
Cheers,
Andy
Lobo
Lobo
Lobo
Re: Speedo knob
October 26, 2020, 10:50:13 PM »
Andy.... try PM’ing ‘Kent400’ wrt this. Peter restores these gauges, and in the past has described how to ‘disentangle’ the knob from the instrument.
(Alternatively trawl through Peter’s posts - there’s a lot of good stuff. Go to ‘Members’, find ‘kent400’ in the members list, followed by ‘Show posts’)
.... kinda like stalking but with an engineering twist 😂
Simon
Last Edit: October 26, 2020, 10:59:32 PM by Lobo
JezzaPeach
SOHC Expert
CB500/4 K1 1972 gold
Re: Speedo knob
October 27, 2020, 02:39:59 PM »
Peter Horton did a good job on the damping in my tacho. He is the one recommended.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
SeanFD
SOHC Expert
"Still running against the wind"
Re: Speedo knob
November 03, 2020, 10:13:29 PM »
+1 on above
CB750 K2 - See: Belfast2BelfastByBike.com
CB450 K1 - A work in progress. (Still!)
CB350/400
Speedo knob
