Author Topic: Hondabond for oil pump/crankcase joint?  (Read 2154 times)
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« on: November 03, 2020, 12:09:07 PM »
When reinstalling the oil pump, is it necessary or advisable to use Hondabons or other sealant on the mating surfaces?
I haven’t seen anything to the contrary so I’m assuming that the torque on the bolts is the standard ones for M6 and M8 bolts.
CB750 K2 - See: Belfast2BelfastByBike.com
CB450 K1 - A work in progress. (Still!)
Re: Hondabond for oil pump/crankcase joint?
« Reply #1 on: November 03, 2020, 12:19:16 PM »
If it has a new o'ring that will seal  ;)
Offline SeanFD
« Reply #2 on: November 03, 2020, 12:32:57 PM »
Thanks Trigger.
It does indeed have a new o-ring, so I’ll just tighten it up.
