Author Topic: Main stand spring  (Read 2873 times)
Offline Athame57
Main stand spring
« on: November 09, 2020, 03:08:51 PM »
I bought myself a shiny new main stand spring, and can I get it on? In the pic you'll see the old one is stretched (or modified) at the longer loop end. I'll swear I've got the right stand on my bike and I did manage to put the old one back on somehow after I had the cracked stand leg welded up. I'm wondering how the hell I did it before. Is there an easier way than pulling at the end so as to get it onto is fixing point....or is there some tool I should have access too? I think the two springs are the same originally.
I brake for animals!
1978 CB400F2 named Elen.
Re: Main stand spring
« Reply #1 on: November 09, 2020, 03:24:37 PM »
Have you used the coin trick?
Bend the spring. As the coils open slide a couple of slim coins/washers in.then bend against the coins. And slide coins in the new open coils.
Hope you can understand. It could  help
Offline Athame57
« Reply #2 on: November 09, 2020, 03:29:42 PM »
Hi John....I'm skint!  ;D Nah...thanks for this, somewhere down the line I've heard of that but it never crossed my mind this or the last time. Well, I've packed up for the day, but I'll smash the piggy bank tomorrow!
Offline Phil Ward (RIP)
Offline Andrew-S
« Reply #4 on: November 10, 2020, 01:09:59 PM »
The repro centre stand spring on my Z900 when 'ping' >:( so I had the same issue.  My hook (that Phil uses) just bent, mine must have been a cheap Chinese import....!
I used the coin method, but bending the NOS spring was a pain in the arse, so I got inventive! ::)  It fitted back on nicely and just removed the coins.
1972 UK XL250 K0 Motosport
1976 UK Z900 A4
2018 BMW R1200 GS
Offline Athame57
« Reply #5 on: November 11, 2020, 04:12:06 PM »
Coin tricked worked a treat... I used the gap between planks on a park style bench to help bend the spring. Better than getting a Honda induced hernia!  ;D
