Author Topic: Carb Rebuild - to do myself or send away?  (Read 11386 times)
Re: Carb Rebuild - to do myself or send away?
« Reply #15 on: November 23, 2020, 07:51:13 PM »
Definitely do them yourself. I sell complete Viton O ring kits as all yours will need replacing. Use the existing brass ware. There are guides in tricks and tips on the forum of how to bench sync and set float heights, there are vids on Facebook and we are all here to help with advice. You can send the to Gerben for a full recondition / overhaul but it's not cheap. Have a go, you have nothing to loose.
[/quote
Hi Julie,
I have have heard you refer to selling parts, where might I find this? Do you have a website?
I sell on eBay, I will PM you the link. If you see anything you need, let me know by PM as I can give you a discount if I sell direct as no ebay or PayPal charges to pay.
Offline waffey
« Reply #16 on: November 24, 2020, 09:25:54 PM »
Hi amx1992
post look good, think i will try JB Weld Steel stick once i get to rebuilding them.
I stripped the carbs further tonight, just that one tank float pin to get out...grrrrrrrrrrr
Though they look they are just chucked in a cutlery draw, they are all in order ;D
Bikes:
Triumph Street Twin
Suzuki Address 110 Scooter
Suzuki TL1000s
BMW R1200GS LC
Honda CB400 F2 1977 (restoration underway)
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #17 on: December 02, 2020, 08:34:03 PM »
I had a full set of 400 carbs with broken float posts, I used an m3 grub screw and made some posts on a lathe/mill
(Attachment Link) (Attachment Link) (Attachment Link) (Attachment Link)
On my 750, I use a piece of plastic tubing as a mould into which I pressed steel putty.
I had to put a little extra above and below the join as I wasn't happy it was strong enough.
It worked and is still working 30,000km later.
CB750 K2 - See: Belfast2BelfastByBike.com
CB450 K1 - A work in progress. (Still!)
« Reply #18 on: December 03, 2020, 05:37:50 AM »
I have used a piece of cut down / shaped  curtain rail  bracket  as source of nylon to repair  a gearshift detent spring mechanism on an imported Nissan. I used fast setting Araldite to sort of coat the finished item - part was not available except as a  complete modified gearshift lever at crazy price from Japan.The fix lasted a good 4 years plus and was ok when I sold the 4x4.
Since then I've used Araldite for lots of repairs though I would not use it on a Carb due to the fuel etc. It did worry me when I dismantled my 400/4 carbs - fortunately they were okay.
I love the inventiveness shown here to repair the broken posts.
« Last Edit: December 03, 2020, 09:34:21 AM by Ted Bagshaw »
Offline waffey
« Reply #19 on: December 04, 2020, 10:36:44 AM »
SeanFD
great idea, I might just steak that. I don't have a lathe and probably the easiest way for me to do the repair
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
Offline SeanFD
« Reply #20 on: December 04, 2020, 12:34:31 PM »
Go for it; all you need is a Dremel or similar to trim the post. But it occurred to me that I might have used Quick Steel and not Steel Putty; it’s quite a while back now. The products were made by Pratley down here.
I see you’re doing a 400F2!
The difference can be stunning! :) Good luck.
Offline waffey
« Reply #21 on: December 05, 2020, 04:26:39 PM »
I am restoring a 1977 F2
Keeping me poor and busy!
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
Offline SeanFD
« Reply #22 on: December 05, 2020, 04:47:01 PM »
What you've done looks good.
I took the poorer man's route and had the chrome parts powder coated - not the rear mudguard, that was isopon :) It looks OK; not brilliant up close, but good from a distance.
Keep at it.
