Author Topic: CB500K2 Carb Rebuild Kits  (Read 2611 times)
Offline Phil Ward (RIP)
« on: November 24, 2020, 11:14:35 AM »
Now onto carb rebuild so whats the current recommendation for rebuild kits for 500. Previously used Keyster kits on 750's I've done but so many on the market now. Lots of chinesse stuff and not sure if what DS and CMSL is chinese anyway. Cruzinimage? (not sure they do them for 500?)
Re: CB500K2 Carb Rebuild Kits
« Reply #1 on: November 24, 2020, 11:24:09 AM »
They did do 500 kits.
If you go to their Ebay store.
Contact seller.
Ask
« Reply #2 on: November 24, 2020, 11:50:50 AM »
Use your original brass ware if you can Phil and I have the Viton O ring kits in stock and the JIS screw kits, sync port screw kit etc.
« Last Edit: November 24, 2020, 11:53:42 AM by Nurse Julie »
« Reply #3 on: November 24, 2020, 12:43:31 PM »
What about the shaped carb top gasket, ist that in the kit Julie?
« Reply #4 on: November 24, 2020, 12:51:00 PM »
No Phil, I don't put them in my kit. We either use the existing ones which are usually fine to use again, or cut our own out of gasket paper.
