Author Topic: Honda cb550k1 throttle cables with uk bars  (Read 4303 times)
Offline Ibby4585
« on: November 24, 2020, 04:56:06 PM »
Could anyone tell me a source to get correct cables for my project that don't cost the earth. Cmsnl want £33 for pull and £28 for a pull cable. Silvers only has a pull cable in stock and I've just bought a set on Ebay listed for a 550 and they are incorrect.
Any info would be great.
I'm in the UK.
Kris
Re: Honda cb550k1 throttle cables with uk bars
« Reply #1 on: November 24, 2020, 05:42:00 PM »
Check out Wemoto.
Just locked and they have some
Compatibles
Offline Ibby4585
« Reply #2 on: November 24, 2020, 06:46:51 PM »
The ones that I bought are from wemoto.
Would the cables from a cb500k0 73' fit they are in stock at Silvers?
Kris
Offline Erny
  • CB750K7 CB550K1
« Reply #3 on: November 24, 2020, 06:48:21 PM »
I'm in the UK.
Kris
I had the same issue - ordered ones from 4into1 (us). But they does not fit properly, wrong length of cable vs sleeve (bowden). Finally got used old ones from CB550F that fits perfect
CB750K7 US model (1977)
CB550K1 US model (1975)
Offline Ibby4585
« Reply #4 on: November 24, 2020, 07:04:27 PM »
Will have a hunt about.
Thats my exact problem, the inner cable  length is too long.
Kris
Offline Ibby4585
« Reply #5 on: November 24, 2020, 07:30:33 PM »
Cheers Oddjob, that would make sense i may take a punt on some 550f ones then from Silvers.
Offline Ibby4585
« Reply #6 on: November 24, 2020, 07:35:27 PM »
Silvers have both 550f1 supersport do they run the same carbs?
Offline Phil Ward (RIP)
« Reply #7 on: November 24, 2020, 07:35:44 PM »
What about having the cable shortened? - https://www.carrotcycles.co.uk/custom-made-cables.html - probably expensive
or Wemoto - https://www.wemoto.com/bikes/honda/cb_500_(four)_k2/73 - think they give dimensions on the item discription
« Last Edit: November 24, 2020, 07:38:50 PM by philward »
« Reply #8 on: November 24, 2020, 08:08:03 PM »
I checked the 500.
At Wemoto.
You need to send them back with an explanatory letter
