Author Topic: CB750 tear down.  (Read 5049 times)
CB750 tear down.
« on: January 11, 2021, 08:34:27 PM »
Rebuilt the rear wheel new bearings, rim, spokes and tyre to put on the road this year. Too much oil leaks etc to run so tear down was the only option.
Tidy up time I think!
Re: CB750 tear down.
« Reply #1 on: January 17, 2021, 05:58:50 PM »
Made a start on engine this afternoon. One rocker shaft with slotted end inwards??. Centre bolts under rubber pucks not very tight. Any tips on separating head from barrels? Don’t think it will be any advantage taking them off together still got to separate them.
« Reply #2 on: January 17, 2021, 07:06:09 PM »
The threads under the cam towers are a weak thread, helicoil while apart  ;)  Make sure that all the tower threaded holes have a bottom to them. Common problem is owners put the wrong bolts in the wrong holes and punch the bottoms out which, cause oil leaks you will chase forever. The black bolts with 9 on the head must go in the middle and the shorter ones to the outside of the towers.
If you have all bolts, nuts and washers out of the head it should just pull off. That's if you have the front and rear M6 bolts out and the special bolts that are in the puck holes x 4 of those.
« Last Edit: January 17, 2021, 07:11:19 PM by Trigger »
« Reply #3 on: January 17, 2021, 09:10:57 PM »
Thanks Trigger. Yes tower bolts were correct. All bolts loosened including front and back. Wonder if someone has had a go at sealing up oil leaks, there was a lot of silicon on the outside of the joint between head and barrels. Problem is with these fragile fins you dare not lever or hit anywhere. I will check all these threads thanks.
« Reply #4 on: January 17, 2021, 10:25:44 PM »
If you have the bolts out of the 4 puck holes then, it should lift off. If you have to hit the head, do it with a rubber mallet to the side of the fins front and rear to shock. If it is still stuck then, there is a point on the barrels to leaver the head and barrels off at the same time. Once off you can knock the head off from the bottom of the barrels with a lump of wood  ;)
« Reply #5 on: January 18, 2021, 02:23:15 PM »
Success with the separation this morning. It’s amazing an overnight rest with a bit more light too. New day and patience restored.  Pics to follow when they upload to iPad.
« Reply #6 on: January 18, 2021, 05:56:35 PM »
Bit of cleaning this afternoon old gasket surfaces. Pistons fitted wrong way around.
« Reply #7 on: January 20, 2021, 07:05:17 PM »
This is not good, started taking some measurements today and the camshaft lobes are 4 - 5 thou below lower tolerances. So it is toast. Don’t suppose anybody has one laying around?
« Reply #8 on: January 20, 2021, 08:06:34 PM »
If the cam is that far out then, the follower must be fecked  ;)
« Reply #9 on: January 20, 2021, 09:08:20 PM »
Is it obviously worn on the tips of the lobe?
If not, it's possible it could have been ground on the base circle to "effectively" increase the valve lift.
« Reply #10 on: January 20, 2021, 09:39:37 PM »
Yes you can see by the profile of the lobes it is worn. The followers didn’t appear to be bad to the untrained eye.
« Reply #11 on: January 20, 2021, 10:28:21 PM »
Johnny, what number has that cam got on it? The number will be near where the sprocket goes.
« Reply #12 on: January 20, 2021, 10:44:25 PM »
It’s an R8 Julie.
« Reply #13 on: February 09, 2021, 09:45:14 AM »
I have no evidence to suggest this engine had been dismantled by previous owner other than the fact that there was one oil restrictor missing! There is minimal wear other than the camshaft lobes. Crankshaft is good main bearings big ends and small ends good, pistons and rings good. Scars on one or two of the mains so will replace them as well as primary and camshaft chains, tensioner etc. Maybe wounds from when the drive chain decided to break into the crankcase. The pistons are standard size Honda stamped, but why would somebody decide they were in the wrong way round? Bores very good no scores and no lip. So the stupid question is did the restrictor missing impact on the delivery of oil to the camshaft or did it deprive delivery elsewhere with the reduction in pressure?
Offline Phil Ward (RIP)
« Reply #14 on: February 09, 2021, 10:47:25 AM »
An oil restrictor missing would severely reduce oil presure to that side and cause damage quite quickly I would suggest. Also, you say pistons in wrong way round but not been stripped previously? Or do you mean not stripped by last owner?
