Author Topic: What does the 400 engine weigh without head & block ?  (Read 8390 times)
« on: February 05, 2021, 11:40:51 AM »
My brother is visiting me in the morning to help me lift out the engine - it will be more a case of him lifting with me directing the process.
I am wondering does anyone know the approximate weight of the engine minus the sump, head & block ?
« Last Edit: February 05, 2021, 12:18:35 PM by Macabethiele (Ted) »
Re: What does the 400 engine weigh without head & block ?
« Reply #1 on: February 05, 2021, 01:50:01 PM »
I don't know the precise weight Ted but if it helps, I can just about pick it up on my own but I wouldn't want to carry it too far 😁😁😁😁
Offline robvangulik
  • Honda Fourever
« Reply #2 on: February 05, 2021, 04:27:43 PM »
A complete engine weighs just under 60 kilo's
« Reply #3 on: February 05, 2021, 09:43:29 PM »
I lifted the Kawasaki Z400 engine out on my own a couple of weeks ago. The head and barrels were removed along with the sump, starter motor and clutch. It was still heavy but manageable on my own just a bit awkward lifting it out. It's a lot easier lifting the engine out of a frame that's going to be repainted, it's something else putting it back into a newly painted frame on your own!
« Reply #4 on: February 06, 2021, 12:22:25 AM »
I weighed one without the top end recently to work out the carriage charge Ted. 😉
It was approximately 35kg, noticeably easier to lift than the whole lump.
« Reply #5 on: February 06, 2021, 08:34:37 AM »
I most certainly couldn't lift a complete engine on my own. But as I said previously, I can just about lift a bottom end so it sounds like 35kg is my absolute limit 😊😊😊
« Reply #6 on: February 06, 2021, 10:45:50 AM »
That sounds like the benefits of eating three Weetabix for breakfast Julie 🙂
« Reply #7 on: February 06, 2021, 12:05:20 PM »
engine out on a NJ engine mount by Macabe Thiele, on Flickr
My brother (Paul) came over to visit this morning - we two handed the engine lift initially me on the left side he on the right.
Momentarily rested the engine on the frame when it was 90% out - this enabled Paul to move his grip for the lift out onto a slab of Kinspan.
I think I had overthought the weight & difficulty. I did casually mention that NJ could lift an engine out unaided so this spurned him on.lol
Can you refit the engine with the sump attached but without cylinder head?
« Last Edit: February 06, 2021, 12:07:18 PM by Macabethiele (Ted) »
« Reply #8 on: February 06, 2021, 12:48:03 PM »
No. Sump has to stay off.
The weight I quoted was without clutch, alternator and starter motor!! Well done getting it out. Onwards and upwards now, subject to 'the boss' of course. 👍
« Reply #9 on: February 06, 2021, 12:53:25 PM »
You can refit the engine complete, Honda did on the line, its just easier to fit only the bottom half as the top will build in the frame
« Reply #10 on: February 06, 2021, 12:58:58 PM »
Great work Ted. On the subject of lifting engines, you would never see anything as funny as Trig and myself lifting fully assembled CB750/4 engines. I really do use every scrap of strength I can muster to help take the weight but my goodness, they are heavy. Trig always has a little energy left though to shout at me telling me I'm not holding it right and I'm going to drop it 🙄🙄🙄
« Reply #11 on: February 06, 2021, 01:02:50 PM »
Did they? There's not enough room with the sump on and breather cover, oil filter fitted.
Offline Phil Ward (RIP)
« Reply #12 on: February 06, 2021, 02:05:03 PM »
On the 750's I've built, I've managed to lift the engine off the bench on to progressiveiey lower (by a foot lower at a time) until lower frame level onto a blocked wooded platform, put plastic plumbing pipe (cut in half) taped to frame rails to protect the paint, shimmy engine partly into frame, then leaned over frame (resting chest on upper frame) and lift and manoeuvre engine into position - my assistant (Mrs Ward) then pokes the bolts into engine.
Taking the engine out the same but used a tolley jack to do the lifting as high as possible (non back breaking height wereby I can use leg strength) to then manually lift to the bench.
Heavy but managable. 40 years of daily press ups/chin ups/running has probably helped!
« Reply #13 on: February 06, 2021, 03:19:33 PM »
Here's how I put it back into the frame Ted. Engine on the floor and lifted the frame over it. I put a couple of engine bolts in and put the sump on followed by the wheels and just lifted it up, nice and easy.
« Reply #14 on: February 06, 2021, 03:48:17 PM »
I had a "factory" picture years ago but lost it in one of my moves, sure it showed the engine as a lump but i an old now and Guinness doesnt do the brain cells at lot of good!!@
