Author Topic: forks  (Read 6650 times)
Offline captaindonutbikes
forks
« on: December 15, 2009, 12:31:45 PM »
will a set of 1976 cb550f forks fit a cb550 k3?   ???
cheers
cb550k3 cafe
Offline matthewmosse
Re: forks
« Reply #1 on: December 15, 2009, 12:50:52 PM »
I think so I've always treated 550 bits as interchangable but best if you do so as a unit with things like airboxes. Most difficulties are easy enough to overcome as long as you aren't going for detail perfact for year cb55/4 forks are however shorter.
Re: forks
« Reply #2 on: December 15, 2009, 02:16:40 PM »
Yes as pairs, one has gaiters the other little boots but as long as the headlamp brackets stay with whichever they change as well
Re: forks
« Reply #3 on: December 15, 2009, 03:11:52 PM »
Sorry bit confused there BryanJ
So they will fit but you need the 550f headlight mounts also? 550k3 will not fit?
cb550k3 cafe
Offline Yoshi823
  • Biker to the bone...
Re: forks
« Reply #4 on: December 15, 2009, 03:49:05 PM »
The 550F1 has 35mm forks,the same as the 550F2 and the K3.
The headlights/brackets mentioned are such that all of the electrics are inside the shell of the K3, as against the F1/F2 models had the electrics squeezed into a little box just below the left front petrol tank rubber. As such K3 electrics won't fit behind the F1/F2 headlight shell.The K3 also comes with a Stanley H4 headlight unit, which, although not as good a Cibie direct replacement unit, was far superior to the unit fitted to the F1/F2.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Re: forks
« Reply #5 on: December 15, 2009, 05:29:01 PM »
The gaiters use one bracket the non gaiters a different reason being the gaiters fit to the bottom of the braket. You can put either gaiters or dust caps onto the alloy sliders
