Author Topic: How do I hold this shaft to undo the end nut?  (Read 7112 times)
« on: March 15, 2021, 04:12:22 PM »
I probably should have done it before I removed the clutch etc what's the best way to hold the shaft to loosen this nut?  Is it by popping in a pair of gudgeon pins and putting a shaft through to hold the con rods fast?
I need to remove the circlip to the bearing then somehow presumably tap out the bearing any tips?
this nut by Macabe Thiele, on Flickr
Re: How do I hold this shaft to undo the end nut?
« Reply #1 on: March 15, 2021, 04:30:22 PM »
Put the clutch basket back on an jam a copper waser between the teeth(a penny will do)
« Reply #2 on: March 15, 2021, 04:38:41 PM »
Is there not a risk of chipping the teeth doing this?
« Reply #3 on: March 15, 2021, 04:52:40 PM »
The copper washer should be soft enough,
The RD Yamaha forum recommends a wedge of cloth to jam the gears
« Reply #4 on: March 15, 2021, 04:54:50 PM »
Not chipped one in 50 yrs but if the quenn knew how many pennies and old halfpennies i had mangled oooer
« Reply #5 on: March 15, 2021, 05:17:31 PM »
Defacing a Coin of The Realm .......they can probably still hang you for that!
Offline robvangulik
  • Honda Fourever
« Reply #6 on: March 15, 2021, 05:24:47 PM »
A washer or coin will work fine, I used a piece of cloth successfully many times ;)
« Reply #7 on: March 15, 2021, 08:03:26 PM »
Making progress there Ted with the stripdown 👍
Offline kevski
« Reply #8 on: March 15, 2021, 08:17:32 PM »
Copper coins are now made of steel coated in copper, test with magnet first.
Offline Skoti
« Reply #9 on: March 15, 2021, 08:46:53 PM »
Would an impact wrench not loosen it?
Skoti
1976 Honda CB750F1
« Reply #10 on: March 16, 2021, 08:44:05 AM »
This is my plan.
« Reply #11 on: March 16, 2021, 09:24:12 AM »
Back in the day,
An impact wrench was a chisel and lump hammer.
Oh
And the blue boxed Wessel with Phillips bits that chewed the heads
Offline H2Eric
« Reply #12 on: March 16, 2021, 03:15:46 PM »
That's because the screw heads were JIS (Japanese Industry Standard) and not Philips
« Reply #13 on: March 17, 2021, 03:50:08 PM »
Okay nut now undone with cordless impact tool - prevented shaft rotation with long JIS shaft  through gudgeon pin with plastic pipe sleeve to prevent marking the casing, cam chain was free from casing sides. Gear, spacer Circlip, bearing and shaft etc removed as per the video link  below courtesy of "smoothoperator".
.https://www.youtube.com/watch?v=P1pTk2951lU
« Last Edit: March 17, 2021, 05:40:48 PM by Macabethiele (Ted) »
Offline Phil Ward (RIP)
« Reply #14 on: March 17, 2021, 07:08:52 PM »
Which back when I was starting biking, I (and many others) didn't know! The brit boys said Jap crap screws was made of 'monkey metal' not knowing about JIS
