Author Topic: few bits and bobs up for grabs  (Read 4206 times)
« on: March 22, 2021, 01:10:09 PM »
Hi all,
after the initial strip down and the putting of various bits in various tubs for 'keeping' and tubs for  'moving on' I have finally identified some bits that are no longer required for the update of the Long Haired General's restored 400/4.
Couple of shots of the collective mound of bits no longer required, bell me if you cant see what you might be after I might have it but give me a shout.
All the bits have come off a 1977 CB400F that was parked up in 1981 so they are a bit grotty but a bit of nannying and they should come up ok. I think the thin layer of farmyard 'GAK' that covered the bike has saved a great deal but never the less a sponge and some wet n dry might be in order. I also have a front wheel complete where the hub is good, the rim, not so but if it comes up as good as the rear it shouldn't be a problem for most of you.
Not sure what stuff is worth but have a look and drop me a pm and if I can sort it I will. cheers all
« Last Edit: March 22, 2021, 01:14:12 PM by Laverdaroo »
Re: few bits and bobs up for grabs
« Reply #1 on: March 25, 2021, 11:00:02 PM »
Just a quick update,
clocks
bars
rear indicators
front indicators have already gone but the rest is still about if your interested. I've still got the front wheel also and possibly the a seat as well. Thanks to everyone for buying the above bits, all going into the 'paint and gubbins' fund. Cheers ;)
