Author Topic: Ultrasonic cleaning solution (cylinder head carbs etc)  (Read 6047 times)
Offline WestYorkshireBiker
« on: April 06, 2021, 11:40:03 AM »
Hey. Got an ultrasonic cleaner from Santa and only just getting round to using it. Want to clean a cylinder head first but anyone use these bits of kit and if so what solution don you use as there's loads out there to choose from. Ta.
Sent from my AC2003 using Tapatalk
OW MUCH????????????
Offline Orcade-Ian
    • Older Vehicle Web
Re: Ultrasonic cleaning solution (cylinder head carbs etc)
« Reply #1 on: April 06, 2021, 01:12:26 PM »
I have used Surfex HD from Bilt Hamber in my ultrasonic cleaner for a few years now the parts need to be free from most of the usual crap that accumulates over the years.  I use the same product in my parts washer to soak the bad stuff away.  In the ultrasonic I set the temp at 60 and clean for 30 mins.  If things are really grotty I sometimes take them out after the first 30 mins and use a scriber or small screwdriver to loosen stubborn bits in the crevices and then do them again.  5% Surfex by volume has been good for me so far.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
« Reply #2 on: April 06, 2021, 01:38:28 PM »
Ian
Nice one. Thanks Ian.
OW MUCH????????????
Offline gtmdriver
« Reply #3 on: April 06, 2021, 03:36:48 PM »
I'm currently using Carbusonic EP26R which I got from Amazon UK but I have used dishwasher LIQUID detergent in the past with equally good results.
Basically all you need is a detergent solution to break down the surface tension of the water to make sure that the object is totally wetted out. It's the shock waves from the bursting micro-bubbles which do the cleaning.
