Author Topic: Another bearing journal topic  (Read 3056 times)
Offline waffey
« on: April 21, 2021, 03:43:18 PM »
Hi, had a go at measuring the clearance on one journal using plastic gauge (grey). There's a first time for everything. Not got my hands dirty since I got rid of my MKII escort some 25 years ago
The bearing looks shot but the journal in tolerance I think according to the manual.
Bikes:
Triumph Street Twin
Suzuki Address 110 Scooter
Suzuki TL1000s
BMW R1200GS LC
Honda CB400 F2 1977 (restoration underway)
Re: Another bearing journal topic
« Reply #1 on: April 21, 2021, 06:28:02 PM »
Is the maximum clearance 0.08mm ? If so I'd agree with your analysis, that journal is ok for dimension.
The shells look quite scored (looks like very poor oil condition at some point) presumably the journal is still smooth?
« Reply #2 on: April 22, 2021, 12:47:53 AM »
Def dirty oil, would still run as clearance is ok but your mind will be nagging you on condition, in a workshop condition i would advise it will run but if mine i would change them
Online TrickyMicky
« Reply #3 on: April 22, 2021, 09:12:46 AM »
I am not an engineer, but sometimes you have to take a step back and look at the whole picture, i.e:-  To reach the point that you have, a total stripdown which takes more than 5 minutes, would you honestly rebuild it with the existing shells and run the risk of having to tear it all apart again? It's a bit more involved than chancing your arm with using a spark plug for a second time.
  Without wanting to harp on it, many years ago I worked part time in a car accessory shop, this was in the days of 'kerbside mechanics inc'.  The number of times that customers would purchase a new clutch plate and cover but wouldn't bother with the release bearing! There's only so many times that you want to be lying on your back with a cast iron gearbox resting on your ribs.
  You only want to fix it once mate. Stay Safe. Michael.
« Reply #4 on: April 22, 2021, 09:40:34 AM »
I didn't feel the OP was intending to re-use the shells,  more gaining a second opinion of the journal and dimensions are ok to go again with new bearings installed.
I know what you mean about the clutch TrickyMicky,  once got a car engine going for someone on the bench as he was going to install it in a modified vehicle, advised him to change the camshaft drive chain and gears as it would be about 20 min job (plastic teeth on cam wheel) which he avoided. Within a year it failed and bent alot of the valve gear  ::)
I didn't remind him of that at all  ;D
« Reply #5 on: April 22, 2021, 11:58:13 AM »
Have you decided what colour shells you have or is the marking still legible?
Offline waffey
« Reply #6 on: April 22, 2021, 08:02:12 PM »
Defo changing the bearings but need a closer look to ID then when I go out into the workshop. New van is my main distraction and evening ride outs so the Honda is taking a back seat.
Bike was stood for some 20 years, the previous owner said he managed to get it running but he didnt change the oil etc, just go it running so assume dirty oil.
The whole engine is stripped so I'll change everything that's worn i.e. cam chain, primary chain, bearings etc
thanks for the feedback.
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
