Author Topic: Brake Fluid  (Read 2312 times)
Offline florence
Brake Fluid
« on: April 23, 2021, 01:59:10 PM »
I forgot the world moves on and changes.  I bought some brake fluid, DOT 4, and have only now noticed it is synthetic.  Will this work?  I have read that it is more compressible than Glycol based brake fluid and may cause a loss of feel which for anyone familiar with riding these bikes will know is not an area where there is room for negotiation  :)
I thought that before I rebuild my brake this weekend I would find out if anyone here has used it as I am miles away from any shops
Offline hairygit
Re: Brake Fluid
« Reply #1 on: April 23, 2021, 02:28:14 PM »
Dot 5 silicone fluid works fine, I can't see any reason Dot 4 won't be okay. Dot 5 is great as it doesn't absorb water like Dot 3, and it doesn't harm paint if you splash the tank or frame.
Sent from my JNY-LX1 using Tapatalk
Online deltarider
Re: Brake Fluid
« Reply #2 on: April 23, 2021, 04:37:35 PM »
Have I understood that you can replace the brake fluid by DOT 5.1 without having to clean the reservoir and lines a 100%?
