Author Topic: Fork oil Height  (Read 5719 times)
Offline Yoshi823
  • Biker to the bone...
Fork oil Height
« on: January 11, 2010, 02:09:17 PM »
I know that various people use the proper tool from the likes of Race-Tech for getting fork oil height correct, but I found an easier and cheaper method.
When you've finished with the bottle of hand soap, keep the plunger bit.
Cut a length of plastic hose that you need for the air gap from the top of the fork leg ie. 120mm.
Attach this to the pump/plunger piece, lower into the fork leg and pump away...ensuring that you have some sort of receptacle to catch the un-needed oil.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Re: Fork oil Height
« Reply #1 on: January 11, 2010, 02:40:27 PM »
Let me get this right...
You slightly overfill the fork leg and then pump out to the required depth (120cm in your example) ?
Offline Yoshi823
Re: Fork oil Height
« Reply #2 on: January 23, 2010, 07:21:42 PM »
I'd much rather get the fork oil height correct than guess that I had the right amount of oil in the fork leg...so I always put in too much, pump the fork leg so's to fill the galleries & get rid of any air, then pump out any excess.
As I said, a cheap alternative to the expensive tools from others.
Yamaha R1 2001
Honda XR400R 1997
Honda CB125T2 1980
