Author Topic: What is this part please ?  (Read 2719 times)
« on: June 01, 2021, 05:57:05 PM »
Can't remember what this is it looks like some sort of stop - it has an O ring it looks like it's made from alloy ?
Do I need to fit it inside before I fasten up the crankcase?
what is this part by Macabe Thiele, on Flickr
Re: What is this part please ?
« Reply #1 on: June 01, 2021, 06:04:01 PM »
It's the oil gallery end plug Ted. It fits in the alternator end with the 'pip' being held in place by the alternator casting. Make sure you renew the O-ring👍.
« Reply #2 on: June 01, 2021, 06:51:28 PM »
Thanks I'm guessing 'O' ring isn't included with a normal gasket set.
I did get a set of O rings from NJ for the screw in end caps so there might be one in that set I will take a look  - thanks Dave.
Offline Phil Ward (RIP)
« Reply #3 on: June 01, 2021, 07:00:24 PM »
Try Julie for the o'ring - I got one for the 500 build from Julie
« Reply #4 on: June 01, 2021, 10:11:35 PM »
And dont try starting the engine without the generatorcasing on or you will e trying to find that plug along with using bags of kitty litter
« Reply #5 on: June 02, 2021, 07:46:55 AM »
I'll second that and don't ask me how I know  ::)
« Reply #6 on: June 02, 2021, 05:21:33 PM »
Same way i do!!
