Author Topic: Rear swing arm bush  (Read 2470 times)
Offline JParty
Rear swing arm bush
« on: June 01, 2021, 07:42:22 PM »
Hello!
I’m having great difficult removing the bushes housed in the rear swingarm that isolate the lower shock mount. I’ve tried pressing inside a vice and these bushes are properly stuck. Does anyone have experience getting these out? I don’t have a torch but I guess heat is the next and last option.
Thanks!
Re: Rear swing arm bush
« Reply #1 on: June 01, 2021, 08:25:29 PM »
Socket big enough for bush to pass into one side, socket sized to the outer bush the other side,  bolt right through (put copper-slip on threads) then it shoul be able to wind it through by tightening each end against themselves.
Oh, you'll need a washer each end to stop the bolts going through the sockets.
Offline Phil Ward (RIP)
« Reply #2 on: June 01, 2021, 09:03:35 PM »
As you have said, the vice with appropriate sized sockets have worked for me in the past - they do take some pressure though (my vice is a pretty hefty 5 inch Record vice)
« Reply #3 on: June 02, 2021, 10:23:18 PM »
I pressed out the centre rubber then got hacksaw blade to cut through outer metal ring then collapse, very easy after struggling to take them out in one.
Offline JParty
« Reply #4 on: June 03, 2021, 11:19:49 AM »
Thank you for the suggestions. They weren't budging with the sockets and press so had to get a lend of a junior hacksaw as per oddjob's suggestion and that worked a treat. Thank you again!
