CB350/400
400 f2 carbs
Topic: 400 f2 carbs (Read 4794 times)
cliff7
SOHC Associate
400 f2 carbs
June 09, 2021, 07:48:53 PM »
My bike starts first time and seems to perform cleanly through the revs. It idles fine at 1200rpm and will idle slower although a touch lumpy. However the idle mixture screws do not seem to make a lot of difference when adjusted. Is this normal? The carbs were professionally rebuilt last year.
K2-K6
Re: 400 f2 carbs
June 09, 2021, 08:46:04 PM »
Where do you have the screws set now?
And how far do you move them? Going down below 1/2 (not to set them but to judge if there's any change) and up to near 3 turns out should at least let you hear a response from each cylinder if adjusted while running.
Doesn't sound too bad though from your description of how it runs at idle.
cliff7
SOHC Associate
Re: 400 f2 carbs
June 10, 2021, 10:02:43 AM »
Thanks for response. I have screws set about 2 turns out and even when screwed right in (gently) the bike still idles. Does a plug check on idle help as previously I have only done this on more open throttle settings? Maybe a colourtune!
K2-K6
Re: 400 f2 carbs
June 10, 2021, 10:30:52 AM »
Slightly odd signals it's giving you.
Are you confident there's not an air leak? Spray something like WD40 around carb to head rubbers while running to see if you get a change in speed. Also can the tickover idle speed master control be turned down enough so that it stalls at idle?
cliff7
SOHC Associate
Re: 400 f2 carbs
June 10, 2021, 10:43:12 AM »
Thanks. I'll try that and yes, it will stall when main idle screw is set low. Rubbers are a bit hard but no problem fitting carbs. Also trying to work out how to upload a video so maybe someone can help me identify a mechanical noise (clutch?) on idle.
Phil Ward (RIP)
Re: 400 f2 carbs
June 10, 2021, 11:01:27 AM »
I don't think you can upload a video Cliff, I have a youtube account (easy to open) - post the video on youtube, then cut and paste the youtube link (of your uploaded youtube video) to your forum post - hope that makes sense
cliff7
SOHC Associate
Re: 400 f2 carbs
June 10, 2021, 11:08:11 AM »
Right, I'm not very computer savvy but know a man who is. He's out on his FJ1200 at mo but will ask him when he's back. Thanks.
CB350/400
400 f2 carbs
